New Engine day
my long lost ratchet
home built mount for something
and a unneeded water sheild
how did the welding go?
cheers
i have found that when a tranny isn't sitting up right or tilted on it's tail the reverse selctor can move jaming the shifters. if you pull the back up light sending unit and take a screw driver, push the shifter back int place through that hole.
this might have been your problem or maybe not. i have had this happen more than once on trannies that were shipped to me...
cheers
roscoFJ73 said:
For the new diesel tacho I ll swap a diesel tach into the dash and run the pump pickup sensor to the old sensor wire on the coil.:idea:
Cant wait to drive this thing:D
nice .. :D
for your tacho is from HZJ75 ..? in my HJ60 my tacho get signal from alternator cable .. I'm not sure if you alternator get this pulse ...
roscoFJ73 said:
Can anyone identify these parts? I think they are off the front of my RHD FJ73.:confused:
Clue: They seem to have power steering fluid on them from an old leak.
If you can help ,please post a pic if possible.:idea:
Ross, the part on the right is a splash guard from the right side of the engine. Forget it, it won't fit the 1HZ. I've also seen the other parts lying around, I have no idea where it is from, but it's not needed.
Dave
cheers
That sounds like the problem
I suspected there was a simpler fix than removing the whole engine/tranny but I couldnt wait for an answer.
Dave
Ok thanks Dave:D
Maybe one was for the coil??
Tapage said:
nice .. :D
Dave the 1HZ gets its pulse from the sensor on the injector pump.
I will just be using the old wiring to get it into the dash cluster
I thought the 2H got its signal from the flywheel??
correct. tach sensor is on the bellhousing and signal comes form a magnet in the flywheel.
jan
jan
are you sure .. ? let found a pic of my 2H engine bay and bell housing, I don't have this sensor : eek: although is a aftefactory mod ..
maybe it differs from year to year.
we are just tearing down/building up a 84 hj60, and the stock tach sensor is definitely on the bellhousing.
cheers,
jan
cheers,
jan
Hijack
Greg_B said:
My what a nice clean SOHC you have on that 1HZ...
End hijack!
:D
gb
Thanks for the life jacket, I as worried it would turn into a 2H electrical wiring thread:D
cheers,
jan
yeap .. maybe ..
did you have pics of your bellhousing tach sensor . ?
A diesel cruiser was born
I ran out of light yesterday bleeding the air out of the fuel system so I got up at 6am and had another go.
I pulled all the glow plugs out ,spun the engine until I had fuel at 3 injector trunnions. It took about 20-30- seconds of cranking to get the fuel up.
I tightened everything up,shorted the glowplugs straight from the battery and it coughed some grey smoke and burst into life at 7 am.
It idled so smooth and quietly,even wtih half an exhaust and no muffler that the neighbours must have been real impressed too:rolleyes::D
I got some little jobs like getting proper glowplug relay,exhaust,coolant overflow bottle and some rubber brake vaccumm hose for the booster.
Im looking forward to taking it on along drive for a picture shoot:D
congrates, doesn't it just send shivers down your spine when the engine fires up after all that work?
i know it does for me...
cheers
cheers
Yeah it was a strange feeling, like WTF do I do now,then I realised I will have nothing to do on the weekends anymore except wheel it:cool:
Best thing is I can stop pouring dollars into it:D
Yet another cool build. I love this place, its like McDonalds when you were a kid!!
