I might have one for sale, brand new and ready to ship from Ben's place. Waiting to hear from a local guy if he's interested. PM me if you are.Wondering current wait times, exploring this since Slee isn't having their revised bumper available soon.
Ben i just wanted to confirm that the bumper can take flush mounted baja designs s2 lights, correct?Thanks for all the kind words and pics! It’s great to finally start seeing them installed.
I apologize for the lack of presence on here.
We have been crazy busy. If you guys have any questions you need answered quickly email is best. I typically try and reply to those every day. @Kabanstva let me know if those lights work. We are a dealer for rigid now and will likely be moving that direction on all our lighting. We are actually dealers for just about anything vehicle related so keep us in mind for accessories.
The flushmount S2 pros require 4 screws to mount so I don’t see how that’s possible at all unless you’re modifying the bumper.Ben i just wanted to confirm that the bumper can take flush mounted baja designs s2 lights, correct?
I sent baja an email for the dimensions, but they ended up sending me cut out templates!
@SteveMoraga
Dissent OR bumpers are built to order. Give Ben a call to get set up! Also, take a look at the install for the "No Cut Rear" Dissent off-road no cut rear bumper installation instructions It will give you an idea of what you are working with.
I am considering the same LRA tank, which is why I went with Dissent OR. But, my rig is still with @benc so I will patiently wait for its return!
Thank you! I used these from eTrailer:That looks great BEG! Did you order the brake lights online? Whats the brand and model number?
Optronics LED Trailer Tail Light - Stop, Turn, Tail - Submersible - 10 Diode - Oval - Red Lens Optro
7-9/16" x 3-5/16" Oval. 3-Function, waterproof LED light acts as brake, tail, and turn signal. Durable polycarbonate housing and lens. Surfawww.etrailer.com
I spliced them into a 4-pin to 7-pin trailer adapter that I made and used Metri-Pack connectors. Very simple install. I wired the license plate light into the passenger side light to minimize the wire run.
Yeah. I used a DeWalt drill tap bit. Took two minutes.Guessing you had to drill the brace to relocate the plate?
I have a 10lb tank that I need to mount. Haven't figured out how yet but I like that mount.Has anyone installed one of these or similar on the bumper?
Bracket for 5 lb. Propane Cylinder.
AT is the manufacturer, designer, and retailer of durable equipment for vehicle based expeditions and remote campingstore.adventuretrailers.com
Nope, I thought it was just me since I hadn't seen it mentioned before. I haven't looked into it too closely (and the table was free, so I didn't complain) but it looks like trimming off a corner of the table will allow enough clearance to use both at once.Am I doing something wrong or can you not use the flip up table and close/open the rear lower tailgate? For example, if I wanna have the lower tailgate open to sit on and use the table at the same time. I shot Ben an email this morning but figured maybe others can chime in as well? I know on his 200 series rear bumpers, I’ve seen the table flipped up while lower tailgate is open.
I tried every combination. No dice.Is there an order that will work? Like fold the tailgate down first then set up table? I have yet to install mine otherwise I may already have the answer![]()
