New Adjustable Caster Correction Product?
Home of the Crimson Tide
I just recently saw the same thing. looks very spendy... but I have not researched on pricing.
Has anyone done more research or found pricing on these?
Rube Goldberg, that's a good way to make a relatively simple problem as complicated as possible! I'm guessing,,, TheBigBoy,,, his deal or has a hand in it? Looks like the type of needless, ridiculous, complexity that he enjoys.
There is not a "SUPPER LIKE!" button, so I just hit the like button three times...
Wow, just wow.
If I want to pivot my axle I'll give Christo my cash.
All that engineering & no true rotation of the axle on its' centerline.
Rick's plates FTMFW.
I'll smack the like button a few time for Kevin's comment too.
XXiindustries adjustable caster correction plates can be used in conjunction with drop box’s or aftermarket radius arms (not superflex arms). This will allow people to run much higher lifts with the adjustability of perfect caster remaining. XXi supporting products to follow
:hillbilly:
:hillbilly:
Im interested
:hillbilly:
Yes, however unless you are going to part time your 80 you are pretty much stuck with what we already have otherwise suffer drive line vibrations from a mis-aligned pinion.
To be clear I dont see this product as a smart approach to correcting caster
Especially for $550 odd Aus, when "adjustment" isnt really a feature.....
Washer mod for me, every week, along with offset bearings to add neg camber and caster, to make the truck turn in with big tyres, and welding the broken panhard rod mounts and cracked chassis steering box re enforcement's.
Got the welder out, might as well do the lot :)
Oh,
And moving the front axle forward 30mm for bigger tyres !
