new 40
got some other pieces painted and ready for reassembly. the last one is the color up close
they are alot of fun and easier to work on. and the plus is most of the body panels are pretyy flat and easy to replace.
Can you come over and fix my flat panels?
I keep getting this guy and all he does is drink my beer and hit on my women.
chemstrip out of foutain inn. for everything except the frame and drivetrain it cost 1600. it was a little high but well worth it to me. there is not going to be any rust on this truck anywhere. i epoxy primerd everything as soon as i got it back. if you want the number just let me know.
Your way ahead of me.
Looking really good.
If you need some hardware you can come by the house anytime. I'll take your old bolts in exchange as long as they are salvagable.
sounds great man thanks. i am looking for the hardware that holds the top hatch hinges in the rear. and need some for the door hinges. i have alot of hardware that i have accumulated over the years and as soon as i am finished i was going to see if you wanted them . let me know if you have the hardware i mentioned above.
well today got the body on the chassis, hooked up the the shifter on the column and ran the wiring harnes back into position. tomorrow i will try and install the sides, rear doors and fenders with hood. ill post pics up tomorrow
I'm home all day today working on the cruiser if you want to come over and look through the bolts. Also if anyone wants to swing by and give me a hand or talk shop I'll be around.
414-0563
installed the harness, correctly this time first time was just moc up. got the rear half doors on. put one side on with new seals. hooked the fresh air pull. this was a little tricky not remembering how it was. hung one of the doors. i think i might have to shim the body to make them line up right, not sure. got all the swicthes hooked up and all wiring except the cluster and the coil. wow it took me 12 hours just to do those things. not very good timing considering i cant work on it til next week again. oh well. here some pics of it coming together
