new 40
picked up the parts not happy with the price but there is no rust what so ever even in the really hard to get places.i probably wont give him the tub. hung alot of the little stuff up go primer on most of the lttle stuff. some parts are going to need work so a buddy of mine will cut and replace. here are some pics
on the parts that dont need sanding i am using epoxy primer on the other a filler primer and will have to sand here another of the hood probably the piece i toook without rust.
the other pic is a nice vet that my buddy just finished
the cruiser was originally spring green. i think i might do that been looking around for colors. if anyone has a color they think looks good on a cruiser please post so i can take a look. i am for sure i'm gonna stay toyota colors for that year. my wife wants it like a baby blue. time will tell i guess.
got a little done today on the cruiser. took off the wiring harness, clutch cylinder and master cylinder, all the pedals and all switches. took all the body bolts off and finally the tub. it was a lot of work actually.
appreciated guys thanks, but i have one. ill probably get it done this sunday.
Steve i have some por 15 that i was going to use. i read a little on both, i wasnt sure about which one is better. what are your thoughts?
I've used POR15 and I think it rocks. It dries smooth and is hard as nails. Mine adhered very well but I also went through all of POR's steps of cleaning and prep with their products. I've heard you can scrub w/ purple power, rinse well, then etch with phospo sumtin' another (at the hardware store) and it will work just as well. I've also just slathered some on a spot on my frame without any prep to see how it would stick and it did well.
Top coating POR15 sucks. I've seen their tie-coat (sp) primer not even work well.
Marshall used Rust Bullet on his 40 and it seems to have much less prep - pretty much need a clean surface and you are good to go.
But, if I was in your shoes and had a pretty good frame that I just wanted to protect a bit on the inside and had some POR15 sitting around I would just go ahead and spray the inside of the frame with it. The frame would probably be OK without it so the POR15 wouldn't hurt.
well got the frame cleaned up. it was caked with mud, it took a while to get it cleaned. sunday ill probably take alot of the drivetrain off so i can scuff it up and por 15 the whole thing.
on the frame , there isnt any place that needs repairing of any kind. the plan is to go over it with a grinder and sanding disc with 120 grit, just to take some of the surface rust off, and then just brush the por on top.
that is the ramsey pto winch. what do you want pic off? i can take them now before i go back to work. oh and i found some more parts you are welcome to. just let me know when you want to come buy and get them
sent the body off last friday, purchased paint, got all the little pieces and big pieces primed sanded and ready for paint. now comes the fun and expensive stuff, ordering parts. where should i get my body mounts from. ccot has some fairly priced polyethylene. where else should i check.?
