SOLD New 120 Liter fuel tanks Land Cruiser HZJ76
Status
Not open for further replies.
Texas
I brought 2 new 120 liter fuel tanks with me from HZJ76 which are the same as the 77 series we have coming in from Japan and you might be able to adapt them as a longe range tank for some other cruisers.The tanks come with the fuel sender and the brackets that holds it under the 76.
250$ a piece
So this swaps out for the stock 77 tank? If so, I am very interested.
I hope so,the 76 comes with these tanks from the factory and since the 76 is basicly the replacement for the 77 it should be bolt on in theory.
I will try and testfit one under my Troopy next week or so.If it is a fit fore several Cruiser models I will bring in a few more of these.
So I put my PZJ75 on the lift today and my Troopy has a long range tank in the rear but the oem tank has been removed so I could measure this.
Specs
Troopy fuel tank
37" between frame rails 36"
29" length between frame brackets 26"
11" height on highest point of driveshaft 15" tall so it would need to be modified to clear driveshaft
This is definetly not a bolt in and will require some modifications but since the filler neck lines up and it fits in the designated space it can be fitted under a Troopy but will require cutting,grinding and welding on both the cruiser and the fuel tank.
If I would need a tank I would definetly do this,tanks are new take offs and come with the pickup with return line for the diesel versions.
Also included is skidplate and straps and the brackets that came from the 76 series.
I have only 1 more available now but can get more of these in the future.
Status
