need valve cover help
Lutz, FL
Ok I got a 2f valve cover and turns out there are no threads for the oil cap. I have another the other valve cover with the threads so can i take that sleave out somehow? Also who sells the valve cover seals?
Thanks
Thanks
Who sells valve cover seals? C'mon... :rolleyes: .
My 2f has no threads on the oil fill, I pick up a rubber cap that has 3 ridges to seal it, from Napa, It is cracking after 3 years and neeeds replacement. I will try Toyota next, you can get the seals there also. Befroe I got the cap I used a rubber expandable freeze 1" 1/2 dia IIRC
You can pickup the generic "push-in" at most retail parts stores (NAPA, AutoZone, Checker, etc).
Pablo is right, only later 2F's had the thread in cap, and most of them used the "lower" profile valvetrain thus won't work with the F engine. For posterity, I beleive the "tall" profile with the screw in cap for the 2F was 01/79-7/80, as seen here:
attachment.php
attachment.php
Ummm, I've got two 1977s that both have the screw-in oil cap. The push-in is the later version?
Either way there's a cap for you, Bjordnolf.
Not all 'F' engines have the tall valve gear. The 2F cover will fit the'F's that have a flat topped steel cover. Changed when the carb went two barreled and the ports siamesed ?
If you go to SOR for the little v/c seals buy the whole v/c gasket because you get the seals with it and it's cheaper, or nearly cheaper, than buying the single seals x 4. One of those SOR things.
Hmmm... Got an OEM 75' and 76' in the shop right now, both push-in... I show 1/75-1/79 as a push-in, and 1/79-8/87 a thread-in?? But as mentionied the 7/80 & later are the low profile, thus won't work on a "tall" valvetrain... I make no gaurantees on a the low profile stuff on a low profile F engine as you mention...
PS... my 76' FJ55 also has an OEM push-in, and the engine that is actually in it (out of a 77' FJ40) has a push in? What gives?
Dunno for sure, but it might have something to do with one of my '77's is a JDM BJ40. :)
As to the other one all I can do is guess that the PO chain is involved - probably got a different cover somewhere. I've never had a reason to consider whether it is the original cover before now.
Guess I wasn't thinking right at 2:42 am - I didn't mean to pull your chain.
Hmm, my 74 FJ55 with an F has threads. Whats with that?
my 70 came with a valve cover with threads. maybe it was the po's doing. and its also a 1f.
Both F's, only 1/75' and later had the push-ins, so your are both normal. Not sure about earlier motors...
B6i6K6e6R6b6O6y said:
so your saying that my valve cover is stock?
If it is a steel stamped cover, then most likely... if it is aluminum, no it is not stock.
so if someone was to go to the local parts store and order a valve cover for a 1970 fj40, it would have the screw in oil cap?
i really doubt that your local parts store would even be able to get you a valve cover........unless the sign above the door included TOYOTA in the name.
In 1970 the valve cover did not have a screw-on cap, or a cap of any sort.
:confused: ????
you lost me
