'91 FJ80, 4.88's, ARB's, Marlin 'moly shafts and Birfs. The previous owner reported "rebuilding" the axle shortly before I purchased it last December. It had no leaks or issues at the time, and everything inside does appear to be new. Fast forward 4000 miles of mostly dirt and gravel roads, and the knuckles started weeping gear oil pretty heavily. I popped the axles out and there is no grease in there at all, and gear oil leaking out of the spindle. Like when you pop the drive plate off oil puked out. So here is the question, should I replace every seal in the whole thing or just replace the inner seal and re-grease everything? If so can I replace it without removing the whole knuckle? I'm assuming that the seal is from Marlin Crawler as well, and I understand those are known to be leak prone. Also the Birf has a little bit of slop in it but no cracks or noticeable wear, I assume it's normal. Thanks for any advice.
