So I bought this for $500, so it might have been expected! I will post a video of what it is doing! It is on the 5th cylinder and It quits when I disconnect that spark plug wire. What do I need to look at next?
I will be sending some oil off for analysis, but would like to know where to start looking. There didn't seem to be any metal in the oil when I changed it but is was very dirty.Check the oil for metal? If the knock goes away when the spark is cut that's never a good sign.
What would that mean?Are the deposits on that plug powder and ashy? If so sounds like you have extra oil in that cylinder.
I pulled another plug to compare, and it had the same deposits on it as well as being oily!Are the deposits on that plug powder and ashy? If so sounds like you have extra oil in that cylinder.
If that was the case, would you try to fix it or find a new engine?IMHO, Spun rod bearing, the spark plug removal reduces force on that bearing and reduces or eliminates the knock. The combustion composition and condition of that spark plug are a secondary unrelated issue.
It's a 95, what do you have for engines? Thanks,What year is your rig? I have a few engines I could let go of. Sounds like you are going to need one.
Well, I think I will go that direction. I just need to find one!I would find a used motor. Leak down test, compression test and possibly replace the head gasket and throw it in.
The oil pressure is good, and it seems like the power is fine. I am near Springfield Mo!Post your location, possibly someone knows of one nearby.
Curious about the drivability of the truck. Low on power with low oil pressure?
