Need Help Diagnosis
OK. I also have a 91 cruiser with the awesome but sometimes frustrating 3fe! Now I also had an intermittent warmed up no restart and power loss issue. After months of changing alot of the fuel system parts. Fuel damper,fuel filter so on. My prob turned out being the fuel pressure regulator. Got one on e-bay for $50. It had gone bad which in return damaged the check valve on my fuel pump. So fuel pump was also bad. Mine wouldn't start and sat for days due to the pump,FPR. Hope this helps because it sounds like a fuel issue you're having. Good luck!
There has been a lot of information and ideas and possibilities thrown around on this thread, but only one makes sense to me.
You need to start from the beginning. As was already stated, you were led down the primrose path twice.
The timeline that I get from your original post is that this truck was running OK but hasn't been looked after in quite some time. Then there was an unexplained and undiagnosed power loss. Then a very bad, and possibly damaging, attempt at a half-assed "tune up" was done by a knucklehead. From this point forward, the truck was in very poor condition.
If this is the case we really must start from the beginning with a good tune up, using OEM parts which you will purchase from one of the many Cruiser specialists running Toyota parts departments on this forum.
1. Electrical issues really need to be sorted out before you continue. If the battery is faulty, replace it. If the terminals are corroded, clean them. If the wires are in poor shape, they need to be addressed. The truck runs on battery power. If it's not getting the right stuff, not much will happen. People love to blame anything and everything regarding a 3FE motor on the EFI relay. If the CHECK ENGINE light illuminates when the key is in the ON position before cranking the starter, then the EFI system is good. Move on to something else.
2. Your motor will not do well with generic or aftermarket ignition parts, regardless of the stated "quality" or price. That includes your ignition coil/igniter assembly, distributor cap and rotor, plug/coil wires, and spark plugs. Considering the person that did the "tune up" had absolutely no clue, you will want to replace any part he put in. People will tell you that you can, and that they have run all sorts of aftermarket stuff with no ill effects, but I bought my truck in July of 1991 and have gone through countless aftermarket parts from countless manufacturers over the last 25 years. Trust me when I say you want OEM parts. Nothing comes close.
3. You mentioned you replaced the ignition coil. If your coil was bad, the truck wouldn't run. It is most likely fine. There are tests you can do with a multimeter to verify the integrity.
4. The aforementioned knucklehead dumped a can of carburetor cleaner into an engine without a carburetor. That in itself wouldn't have done any damage, but I need to know the delivery method. HOW and WHERE did he spray this stuff? Maybe he screwed up your air flow meter, which would cause all sorts of headaches.
Please look at this document regarding part numbers and tune up information:
http://www.sdsysdesign.com/tlc/images/Strife/3FE TuneUp.pdf
Here is another with some diagnostic tests to help you get on the right track:
http://www.sdsysdesign.com/tlc/images/Strife/3FE EFI Diag.pdf
The 3FE is a remarkable engine and will last forever even when mistreated. You can pour beer in the fuel tank and urinate in the crank case and it will run for another 50K miles. It is made to run with little maintenance on sub standard fuel in harsh environments.
^^^^ He has spoken. Take the words of @jonheld as the gospel. Follow his guidelines. He knows the 3FE better than anyone. Period.
Just a stupid thought but you might check that the spark plug wires are going to the proper spark plug IE: #1 spot on distributor to #1 spark plug and so on.
I want to know how @jonheld knows this:
"You can pour beer in the fuel tank and urinate in the crank case and it will run for another 50K miles."
We can all surmise a guess, but the reality just may be more interesting........
That would make a great sig line for you @LS1FJ40!
In 2000 and 2001 I drove my 1992 from Indianapolis to Baja, Mexico and back. It was a total of nearly 6,000 miles round trip, much of it in Mexico. At the time my 80 was "built" and I carried 3 jerry cans. I stopped to pour the jerry cans in my 80 as I was getting low on fuel. I "cracked" them open to vent. It was 110 degrees out at the time. The vented for about .5 of a second. Not the usual 4-5 seconds. I leaned down and smelled the "gas" and it hardly smelled like gas. I didn't have a choice but to pour it in and hope. She didn't skip a beat. There were multiple "gas stations" where I filled up out of five gallon pails, milk jugs, etc.
The 3FE was designed for harsh environments and harsh treatment. And has the electrical (or lack there of) to accommodate that.
With @jonheld permission I would love to use that as my signature. :)
I just re-read this. You said you put a bottle of carb cleaner in it. Like Jonheld said, this doesn't have a carb. However, what would make sense is IF you put a bottle Seafoam in through the Brake Booster to clean up the throttle body (this is pretty common), then yes, you are going to get a massive amount of smoke billowing out your tail pipe.
If that sound like what you did, then I would not be overly worried about the smoke, since that is normal after a "top-end" treatment and will cook off once it is able to run long enough to do so.
If you didn't do this, maybe @jonheld can clarify, but would an issue with not enough fuel delivery (clogged filter, ect) cause black smoke? Seems like this would be more like too much fuel or fuel that is not being burned completely.
OK I am out working on mg truck today. I found two hoses the mechanic took off :/ I also checked the wires & they are on correctly now. The engine still isn't turning over & I'm trying to get a diagnostic code, but its not giving me one yet. I may not be putting the paperclip in far enough. I also checked the coolant, and it was almost dry, but clear. It smelled a little burnt. I think I need to drain and replace with the red stuff. I don't see how that could affect engine start though. I've never had indication it has overheated before, and the coolant always been at a good level.
I don't have the socket to pull the plugs. Last time I came out with a friend, he pulled one and said it looked great. I'm going to go down the rest of the list and come back to that.
Wow that explains a lot ;) lol
Very helpful info and I appreciate the delivery. I think he put the carb cleaner in the throttle body.
You stated it is not "turning over". Does that mean it is not cranking? If not, that's a different set of problems (battery, battery posts, fusible links, starter, ignition switch,...)
There may or may not be a code. If you can get the check engine light to blink with the paperclip, then you are doing it right. Then it will flash the sequence of numbers. Does the check engine light (CEL) light up when you turn on the ignition? If not, that signifies other specific conditions, in addition to it could be a burned out bulb.
The check engine light isn't coming on anymore. It was the other day when I was working on it. So I think the bulb is okay. The paperclip just isn't doing anything. I used a small one, a big one, and a bobby pin with the plastic tips taken off just to make sure, and inserted it every conceivable way.
As far as it "cranking" or "turning over" the best way I can explain is that the ignition seems to work, and it begins to start, but doesn't. It seems like its either not getting fuel, or spark.
The "A/T Oil Temp" light is on, and the light above the battery meter. Its registering at half charge on the meter, but my friend checked it with a tool the other day and said it was fully charged. Its only a few months old.
OK, so when you turn the key to the "start" position, it will crank and turn over, but will not start and does not appear to fire. Is that correct?
Does it sputter, like it fires on a cylinder or two, but not enough to start? Or does it just turn over?
It is possible the code cleared due to a dead battery or unhooking the battery cable. i suggest hooking up jumper cables or a charger to the battery to continue your diagnosis. Assume the battery is near dead, just because it has not run, but has been cranked a lot.
Latest development, got a jump to see if it would turn over. It didn't sound any different than trying to without the extra help. Its definitely not getting fuel. Taking a lunch break to regroup and cool down...
When I turn the key, it sounds normal, and no sputtering. Just doesn't crank up. It starts, but doesn't turn over.
Umm....it starts but doesn't turn over?
What do you think "turn over" means? I'm not talking a hot apple pie from McDonalds here.
Starting means the engine runs when you release the key after turning the key all the way to the right for a few moments while the engine cranks. Once the engine starts, the driver releases the key and the engine should be running. If it is running, you will hear things moving under the hood and exhaust will be coming out the back.
If you turn the key all the way to the right and you hear a RRrrRRrrRRrrRRrr sound, it is cranking.
If you turn the key all the way to the right and all you hear is a "click", it is NOT turning over or cranking.
If you release the key and all is quiet and nothing is moving, it did not start.
As stated: three things to make an engine run; fuel, spark and air. If you're turning over then you're getting power to the system. You can pull a spark plug with the distributor wire attached and ground the threads on the block while blipping the starter to check if you have spark at the plugs. If you do (and I suspect you do) then you likely have a fuel problem.
Check each of your three major systems to ensure they are working. That should get you at least running - even if roughly. From there you can start diagnosing why its not running well.
And just to be clear, when I changed the fuel sock, I saw the tank full of fuel ;)
OK That's a good bit of info to know.
Don't get me wrong, I'm not trying to be an a-hole in my post, I'm taking my description back to the most basic, starting at the "beginning" so to speak.
