Need Help Diagnosis
Umm....it starts but doesn't turn over?
What do you think "turn over" means? I'm not talking a hot apple pie from McDonalds here.
Starting means the engine runs when you release the key after turning the key all the way to the right for a few moments while the engine cranks. Once the engine starts, the driver releases the key and the engine should be running. If it is running, you will hear things moving under the hood and exhaust will be coming out the back.
If you turn the key all the way to the right and you hear a RRrrRRrrRRrrRRrr sound, it is cranking.
If you turn the key all the way to the right and all you hear is a "click", it is NOT turning over or cranking.
If you release the key and all is quiet and nothing is moving, it did not start.
It is cranking. Apparently I need to listen to Car Talk podcasts more often.
OK That's a good bit of info to know.
Don't get me wrong, I'm not trying to be an a-hole in my post, I'm taking my description back to the most basic, starting at the "beginning" so to speak.
Definitely not taken that way at all & it is super appreciated! There's a lot of info here & its overwhelming trying to backtrack and figure out what caused what due to the idiot I paid to do this. If that's even related at all. I suspect the idiot just confounded an issue already happening. I think I cleaned up the idiot mess and need to get back to basic, which is why isn't it getting fuel? Hopefully its something simple.
OK...:)
Is there another person there that can assist you?
If so, one will be in the driver's seat and the other will be under the hood.
Find the center wire on the distributor cap and gently pull it off of the distributor cap ONLY. This is the COIL wire. This feeds spark to the distributor. Lay the wire near something metal, so the tip is less than 1/2" away from any of the following: exhaust manifold, intake manifold, alternator bolt, or some steel part of the engine. Do NOT run it close to the belts.
Let go of the wire and let it rest there. What you will be doing is cranking the engine and looking (or listening) for a bright blue spark. WHILE the engine is cranking, you will hear a rapid snap, snap, snap and should see a bright blue spark arcing from the coil wire to the metal.
You CAN choose to hold on to the wire and then you should fully understand what is meant by spark. If it doesn't shock your ass across the room, then you don't have spark.
If you don't have the snap or see a spark, you may not have spark. It may be that you didn't get it close enough to the metal part. Try again. As a last resort, stick you finger over the end and crank it. If you don't get shocked, you definitely don't have spark. If you DO get shocked, then you will swear, pee yourself a little, and may hit your head, but at least you will know you have spark.
Try it now.
Also, do you have a FSM (Factory Service Manual)?
My awesome little 5yo girl helped me turn the key, and yes I have a manual downloaded on my phone.
And no spark. I didn't have the guts to put my finger on it. Just not in the mood to pee on myself today! Or in the crankcase like some ppl like to do! I did touch it directly to various metals and nothing.
No, it's not the wire. That is a spark test to see if you have spark. Now is where we call upon @jonheld again. The '91s I am somewhat unfamiliar with in that each item is controlled differently.
No spark can be a result of the computer telling it not to, a bad fuel pump relay (FPR), or others. I am not sure what triggers the spark on the 3FE.
@LS1FJ40 may also help. GUYS?!?!?!?
What's the next step on the 3FE?
In the mean time:
With your 5YO at the helm, go back to the fuel pump area (just be right next to it) and have her turn the key to the "RUN" position (the one right before "START") and listen for a brief vibration that would sound like the fuel pump pumping up to pressure. it may only last a second or two. Have to be real quiet to hear it.
After you determine if it is or is not working, then go out under the hood again and open up your large black air filter canister. Undo the wingnut off the top, and unclip the 3 clips to lift the top of the canister.
Look at the air filter in there. I should "look" clean and not be soaked in oil or have mouse nests in it and it should not be stuffed full of junk.
After that, open the fuse panel under the hood. (I'm not sure but I THINK it is on the left (driver's) side on the '91.) and pull each and every fuse and look at it to see if the little swirly piece in the middle is still intact. If there is one that is burned out, you will need to replace it. Do the same on the one in the cabin by the driver's left knee. Do all of them in order so you don't get lost or put them back in the wrong spot.
This ought to keep you busy for a little while.
first thing, punch your "friend" in the nose and get your money back.
what kind of "carb cleaner" was it? seafoam? seafoam will make a smoke cloud that could hide a bus but you have to add it straight to the intake and it will make it die when too much is dumped in there. like someone else said, check the plug wires. if theyre not in the right spot it will run but not very good. also vac leaks cause it to run horrible.
if your plugs have an ashy look to them its the additives burning.
I don't know what it was. I was elsewhere working & he said it was from his shop, that you can't buy it at a store. I saw a small can and it looked nothing like the cleaners I saw at the store :/ He also said I owed him more money for a second one he bought to run through (the carb in don't even have). No punching yet, just not so nice texts :)
In the mean time:
I did not hear a vibration from the fuel pump.
I already checked all the fuses and air filter..among the first things I did. The filter is really clean, and no rodents or Barbie dolls hanging out.
I also tried the coil again several times, and no spark.
OK.
Engine cranks.
No Spark.
No Fuel.
No Code.
Fuses good.
Possibilities:
Air Flow Meter (or whatever it's called on this truck)
Wiring harness unplugged
Starting circuit bad
I'm going to need to think on this one a bit and re-read what you've already posted about how you got to this point.
Give me a "bullet list" of sequence of events. When you bought the truck, how long you've owned it, what it's usage has been, when did you last drive it, why did you have yahoo #1 and 2 work on it, where the truck currently resides (I'm assuming your house and not a shop)
Do you have other transportation available?
You did this WHILE CRANKING the engine RIGHT?
LOL you've done that too? i did it on my dirt bike as a teenager and about s*** my pants!
Yeah...under the hood of a 69 Chevy 4x4 with an HEI distributor. Knocked me backwards out from under the hood, hit my head on the hood pin on the way by, then landed hard on my shoulder outside the truck. I was sitting in the engine bay on top of the radiator support. I had a remote starter in my hand and hit it to turn it over, and got 40,000 volts to one arm that made me jerk HARD. You tend to learn after that.....and convincing a neighbor to pee on an electric fence.......:)
was it this stuff? http://shop.advanceautoparts.com/p/...-and-diesel-engines-16-fl.-oz.-sf16/6410004-P if hes putting a whole can of the stuff in there no wonder why its not running. youre not even supposed to put a whole can to an entire tank of gas...
edit* i just seen youre not getting spark but it could explain the smoke cloud...
What did he take off to get it into the throttle body? Any electrical connections? There is a plug to the distributor that may have been removed.
Oh yeah....don't forget to hook your coil wire back to the distributor cap.
Start checking all the electrical plugs to see if any are loose or one that is "newly removed" meaning that there isn't a bunch of dirt/grease on the unplugged area. An open, dirty plug is one that is there for an option.
And BTW, Seafoam is EVIL.
