need a little ligthing help
charleston,wv
After not have the "D" light working on the dash for quite some time it finally started working again, but now my dash lights aren't working. I don't have the FSM so I was wondering if anyone could post directions on how to get to the lights for replacement.
Thanks
The typical dash lighting fix is a firm hit to the top of the dash.
With that said, it didn't fix my no D.
You gotta pull the entire instrumenmt cluster out of the car and then you can access the individual lamps. Not difficult but by the time you've pulled everything to get to the cluster, probably a 2 hour job in total. Take your time and don't pull too hard.
Rgds..
I've been hitting the dash past 2 days and hasn't worked, the "D" light only came back on from the rough unplowed roads in morgantown. How do you pull the instrument cluster out, I don't want to break anything.
My "D" isn't working either, I'm not freaking about it, it's not high on my priority...the sunroof leak is killing me!! But I wouldn't mind hearing how to fix it...I like the projects that require my time and a $2 bulb!
Wait, wait, wait. What "dash lights" are you talking about?? The entire dash has lights on it and people are telling you to pull instruments already (very much more work than some dash lights). Be more specific here.
I'm guessing he's talking about the "D" for "Drive" when you move the gear shift on the autos into the "drive" position.
I have a similar issue. My "Overdrive" light on the dash is not working. Very close to the "D" so I'm guessing I can also benefit from this info.
My guess is that it'll be a whole lot of stuffing around, maybe break a few tabs I didn't know were there and even lose/gain a few screws in the process...
If anyone has done this before (be good to have a writeup) then please chime in...:popcorn:
i should have stated that a little more clear, the gauge cluster lights along with AC and heating control lights went out on me. Whenever i turn on the headlights there's no backlighting for the gauges or controls.
I didn't mean the "D" light was out, it randomly came back on after driving on a rough road one day and has been on since. But the gauge cluster lights are the only lights out now.
Did you check fuses? Do you have a brake light out (not sure on the LC but on a camry I owned once, if you had a tail light out, your dashlights won't work to let you know)?
^ x2. If all of your lights went out, it has to be a fuse issue.
My D light is out too. Probably because unless you are parked with your GF for a long time, D should be the most used light there :)
This would be a good writeup for the FAQ if anyone wants to document it.
X2
Or make sure it's still plugged in.
Among the many burnt out bulbs I had to replace, the three bulbs in the climate controls were out on mine when I purchased it. Pulling out the console is pretty simple - I think there are writeups posted. However, IIRC, there are two screws around the ash tray and two more in the cubby above the stereo (be careful pulling the plastic insert out or the two retention tabs can break. Then just gently pull out the cover and disconnect plugs until youcan access the climate control 'box'. I have auto climate on mine, so it may be different than yours, but I had three bulbs to replace. Pretty simple job.
HTH
Bob
Well I've got a short somewhere I'm pretty sure. Pulled the fuse out of and it was partially melted on the left side, terminal was black. Put a new fuse in and the gauge cluster lights are working again. I've been having problems with the gauge cluster lights cutting off every few weeks since november but the fuse has been good until now.
