Fairly certain I have a grounding issue, not sure if I missed a connection or what. Here is the back ground. Just completed a complete front end overhaul / rebuild. Engine out, new (used) engine harness from behind the dash forward. Replaced the engine main ground with an over-sized 1/0 ground to the battery, cable to the starter was also up-sized to 1/0 because I had it.
Occasionally I will get this combination of lights:
Low battery indicator (needle drops to mid gauge), low oil light, brake light, and AT/Temp light. then it goes away. I am getting a noticeable alternator whine in my radios...
Was over-sizing the engine ground a dumb idea?
