I pulled all hoses and flushed EVERY direction (forward and backward) with a garden hose after the initial drain. I had 20 minutes of brown crap running out of somewhere.
I did (6) distilled water flushes without a thermostat (in summertime), drive 14 miles each way to work, come home, let it cool a bit, then drain by pulling lower radiator hose and block drain. Basically until it ran clear.
Then refill and do it again. Every day for a week. Then on Saturday, I installed the new thermostat and gasket, drained, and refilled with Toyota Red. Still looks like Fruit Punch Gatorade!
Mine started because of the mix of brown sludge green/red mix from the PO and a blown radiator.
Make sure you run the heater on HOT while driving as well as the rear heater so it all circulates well!
When I do mine next, I will completely flush and switch to green. It's cruiserdan approved!
