My new 80
Eastern Iowa
Hey my name is Kevin. I'm from Eastern IA, new to IH8MUD and TLCs. I picked mine up for $4,500 rust free (Texas) with lockers (thanks Mike if you're lurking). I'm no stranger to wrenching but am new to SFA and 6 cylinders. I turbocharged a honda civic when I was in high school and prior to this, was my daily driver. I also have a 1988 toyota pickup that was rust free from AZ.
I look forward to reading, searching, wrenching and hopefully helping others. In my spare time, I work as an off-highway diesel engine base engine calibration/development engineer. I also enjoy backpacking, canoeing and fishing, and trips to the BWCA with my wife.
Next on my 80, power steering pump rebuild.
Welcome aboard Kevin. Very clean looking 93 there.
Welcome aboard!
It hit a high of 50 here in Iowa so I grabbed some more pictures.
Future work:
PS pump leak
Out of the charcoal canister and into the...? x2?
Wiring nightmares of an old alarm system
AT Leaks?
Source of sticky tar under distributor on upper rad hose
Where in Eastern Iowa are you? I'm in Cedar Rapids and @Dudleyfj40 is near here too.
Nice rig. Welcome! :flipoff2:
Second worst color on an 80 Series. (One of my 80s is that color too :bang:)
WL/CF area. And yes we'll see if a full color change is in my future. It doesn't fit in well with our fleet, also the clear coat is faded on the roof..
Nice. I make it up to WL/CF a couple of times for work. I'm typically in my 93.
PS fluid leak... just make sure that the leak is not coming from above the pump. Sometimes it is just the return line that connects to the reservoir. (Connected to front 90° welded tube on reservoir). Oil will seep from that and all that is required is a new hose clamp (use a breeze style clamp). However, it is just as common to be coming from the pump.
The goop is probably just a slow leak coming from the distributor O-ring. Very common leak and easy fix.
HOW TO: Replace Distributor O Ring
check the easy stuff above first on the ps leak but from your picture it looks like your missing the same part i lost on my PS pump lately - check the last picture in my thread below.
There is supposed to be a part pressed in to the hole indicated by the arrow - either pressed in or a bolt screwed in - I'm not sure....
Either way - mine came out and I lost all power steering - if you pour in ps fluid and it pours out.....this is it - its not a slow leak - it will drain from this hole as fast as you pour it in......... had to jb weld a nut in place to be able to drive home.
Ps pump blown
.webp
Nice truck! Welcome to 'Mud! :flipoff2::flipoff2::flipoff2:
How many miles are on your truck? It looks to be low miles!
Congrats!
Congrats!
Would you consider 215k low? It's in great shape though, thanks POs
Future work:
PS pump leak
AT Leaks?
What are those 4 screws for to the right of the drive select. I have the same on my 91. Was it an old car phone mount?
Yeah, low-ish. My 96 has 226K on it I think. and it has not been driven excessively. Anything under 200K is definitely low miles.
Yes, that was a car phone mount.
I'm originally from NW Iowa and live in the KC area. If you come this way, let me know.
