- Thread starter
- #41
Yes sir. I believe all I use is the bell housing off the 1uz. I have a lot of research to do...Your using your factory tranny for this right?
We should both do full tranny fluid flushes and our power steering flush one weekend this spring and post it.
When does the used parts sale start for the 2L te crowd? LOL
You get farther in an hour than I do in a day! Nice.
Out of curiosity, what car did the engine come out of? I am assuming that it was mated to an A34x transmission, and wondered how that transmission is controlled.
It will be awesome to see this swap fully documented!
I'm sure guys in the U.K. Use the ls400 auto trans mounted to the lj78 transfer case, then use the standard Lexus engine/trans ECU.
I'm pretty sure it's just a case of removing the tail housing for the auto trans and fitting the lj78 transfer case, only thing is you need to drill the transfer case housing for the gearbox speed sensor as the lj78 uses a signal from the dashboard speedo and the Lexus has its own sensor.
This guy started using a 1uz-auto-lj78 combo in a jimny build
Difflock :: View topic - Jimny build
I think you also have to shorten the tail shaft, or swap it. Most people shorten it, as swapping is a huge PITA.
If you want to have the Lexus ECU control your transmission (which I think is a good idea), this is probably the way to go @Postoy .
