- Thread starter
- #81
I got the new Toybox crossmember in and then modified factory crossmember out. Sorry for the crappy night pictures, but they are better than nothing. I know I need to get longer bolts to go through the frame.
I put it in double low (~200:1) and immediately noticed a lot less movememnt in the shifters just from moving the mount back and evenly distributing the weight in the center more than hanging off the transmission.
The plan is to add off of this crossmember and make a hoop that runs forward over the front driveshaft and incorporate a transmission mount that ties into the factory mounts.
I should have some more updates coming up this week.
Dylan
Dylan
that is going to tie into the toybox crossmember. The 'feet' are going to be welded onto this hoop and then go into the frame. This isn't the strongest design possible but based on the parameters I think it will do. I was trying to think ahead and drill out a plate for the transmission base mount, but it is not going to work so I need make a new one and fit that to the hoop shown.
