- Thread starter
- #941
It was super rainy yesterday (and today) but dammit i had a deadline that i couldn't miss, @reevesci lol. So Aidan and I worked through the wet and FINISHED THE SPRING OVER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
We actually tested it last night around 10pm, but i never got above 35mph. It still needed some ATF added to the transmission and the power steering, and we still had to weld up the rear shock mounts and rear brake tabs... and tweak the proportioning valve so the rear brakes actually worked haha.
On the test drive i noticed that i couldn't turn nearly as well to the left ask could to the right, i thought i might've put the steering stops in the wrong place and was really worried until i got over there this morning and immediately saw that the problem required much less welding... just needed to rotate the ram mount up on the tie rod so it stopped hitting the unbolt haha.
On to poser neighborhood shots
Already rubbed the knuckle ball paint off haha, and my ghetto fabbed front spring hanger that i need to replace... those washers gotta go lol
And i need to cut the diff breather.
Street wheelin in the ATL after leaving ACC, nothing was screaming out at them to fix. i felt really good about that!
And Woody's usual stomping ground, sitting still in traffic...
Things id like to look into:
-LOWERING the height. The rear is a little stink bugged and id like to rectify that by fixing the rear shackle angle. Also looking into frenching the shackles into the frame.
-Thats it, everything else is perfect for me. Even the brakes work as well as my brother's 80 on 35s. Im pumped and not scared to drive Woody anymore lol!
And I'm sorry J, my first wheeling trip won't be on the 1st, it got moved back a week or two. So not many awesome off camber shots until then
edit: derp
edit: derp
