My First Frame-Off Resto
Ohio
I have rebuilt the front axle, 82 FJ60 Disc Brakes, Pulled the front spring packs apart and wire brushed and brushed and brushed................
Actually, I am trying out an image resizer so I thought I would put this thread on and see how it turns out. If it works, more pics to follow.
Here's a shot of the blown up muffler that happened a couple of months ago. There was a slight timing issue (unknown at the time) and I was trying to get it started. Apparently, some gas/vapor collected in the exhaust.............
My ears were ringing for about 30 minutes after this. Thought a 60mm Mortar went off next to LC1
Nice stuff! Those shots of the front axle/hub rebuild look like your doing a lot of good stuff. How did you clean it before you painted it? POR15?
Keep them coming!
Georg [orangefj45] has a similar muffler story. Funny unless you were there! :eek:
The frame will be blasted/POR once I get the tub off and the engine pulled. I only put the front axle back on so I can move it around. Body is going to require quarter panels and drivers floor replaced at a minimum.
I angle grinder/wire brushed all of the front axle components and used Rustoleum primer/top coat. Not sure if I am going to be happy with that.
