my first engine pull
Santa Monica
Hi everyone,
This is my first attempt of engine removal.
Would it be easier to unbolt the bellhousing from the engine (yellow circled bolts) or remove the bellhousing with the engine (unbolt the red circled bolts)?
Thanks for any info.
What is the purpose of the removal? It is easiest to pull everything at once but for a clutch job that adds alot of work disconnecting the engine.
Shawn Russell said:
Remove the tranny, not the bellhousing...
Shawn
how do you support the tranny when it's seperate from the bellhousing? on mine, the last mount IS the bellhousing mounts
Skid plate does that wonderfully..
Unbolt the tranny (red), but taking it out as whole is probably better, you have to support the tranny and lineing up the trans and engine when you are putting back in will probably be a pain in the ass, they have to line up exactly, you'll probably have to remove the rear drive shaft to slide the trans back anyway.
Which ever way you do it - good luck on the pull.
You can either use a tranny jack, or I remove the tranny cover (which I assume you have already done at this point) and use my engine hoist to hold and lower the tranny/transfer to the ground. Works great!
Shawn
Thanks for the replies,
I'm removing the engine so that I can replace it with a crate engine. I'm
mechanically challenged, so I was hoping to make this process as simple as
possible. I'm worried the more parts I take out, the harder time I would have
to get her running. I was planning on supporting the tranny with a jack while the engine is out.
Thanks again
personally i'd pull it all as one... i know how much of a bitch it is to line up the gearbox back into the bellhousing.
if you are using the same bell housing i would just pull the engine from the bell housing after you support the tranny of course. and if you are using the same tranny, why pull more than you have too, they are heavy and it aslo depends on whos al helping you
I have done it both ways by myself, It was easier putting it together when I took it out as a whole. However, if you are having someone help you line it up when reinstalling it should not matter if you pull the engine by itself. Just my opinion.:)
I pull the motor by itself, I hate the extra weight hanging off the back. It really is not that hard to get it back together when you have the tunnel cover off.
And you do not have to pull either driveshaft..
