Went to the tire shop today, with Slee 4" front springs and no caster correction
-2.3 -2.8
Being this is the case it appears I need between 4-6 degrees to be within the acceptable range. Will too much caster create issues???
basically puts me in the Slee arms, or Slee plates range...high or low side respectively...
I have a set of arms "reserved" I want to just make sure that too many degrees positive caster won't create anymore issues.
-2.3 -2.8
mY guess is that you couldn't get too much of you wanted to. 2 to 4 is factory or normal and just makes it track straiter down the road. IMO You cant get more than that unless you do a cut and turn.
