Well, I finally removed the Aluminum monstrosity which had dominated the front of my cruiser. I am in the process of building a slightly less obtrusive/fugly steel unit. Please note that I KNOW my turn signals are not in the "correct" location, unfortunately the PO placed them on the Alumauglybumper, and I am in the process of trying to locate a set of the correct mounts so I can re-locate them back to the fenders. If you have a spare set that you could part with let me know.
1st pic = layout. 3x2 box tube, 2" x 1/4"FB + some scrap I had.
2nd pic = a decent bead
3rd pic = as it sits now - but not complete yet.
I plan on adding a single hoop, 2"od pipe/tube, coming off the ends at the same angle as the bottom of the bib, with a bend radius the same as the bezel. I figure this should give me about 10" of height overtop of the box tube. For those wondering, there are mounting bolts on the bottom side of the bumper, not quite as substantial as the top, but that will be fixed when I add the hoop.
Any thoughts on what I should or should not do?
