My 40 will not start, please help....
Portland Southwest
Greetings!
I have a very stupid question so please laugh -- I deserve it. I am a new owner of a 1977 FJ40 and have no competent help locally with it -- it's up to me and my 20-year-old son who is helping me -- and we are sooo ignorant but enthusiastic. I planned to drive it today, it didn't start. Mmmm...must have something to do with the interior light my son and I left on when we were oooo and ahhh-ing over it a week ago . . .
Neither of us can figure out how to get the hood open in order to check the battery connections! I can see the hook on the right hand side but cannot figure out how to disengage it. (My Haynes manual doesn't cover "troubleshooting for stupid owners" in the index).
Help?
Welcome.
After you unhook the two hood hooks, there is a latch on the left front part of the bib that if you reach inbetween the hood and the bib, you will feel it....push it back and the hood will open.
After you have the hood open, look at the catch you just pushed out of the way, and there should be a lever that it is a part of, that comes out of the bib, tucked up behind the headlamp bezel....you will see it.
Charge your battery for a few hours, and have fun!
Good luck!
-Steve
Welcome, we don't have to many women fj-40 owners here. If you can post pictures of cruisers here it is like porn to us. You will learn a lot from your cruiser and this site.
This has nothing to do with the battery.
You do understand the choke right? When I got mine I had a hard time cranking it. The way I crank up is Pull the choke all the way out. Pump the gas 3 times and press the clutch in and crank. As soon as it starts I tap it in a hair. As the truck begins to warm up the idle will get louder and louder. Gradually push the cluke in a little at a time to get the idle down to about what you think would be normal. If you go to far on the choke to fast, it will choke down.
Uh, did you read the post...... I think it does. The choke has no effect from leaving the interior light on. I don't think they are even able to roll the engine over.
Cowgirl;
could u tell us what happens when u turn the key to start engine?
Transmission in neutral :
Parking Brake ON;
Choke ON full, pull out all the way. Pump gas pedal 3-6 times.
Turn the key to START, what noises do u hear?
The hood has a safety hook on the inside. Facing the front of the FJ40, your right hand on the released hook, pull up. The safety hook will stop any further lifting. Above the "T" in the bezel label TOYOTA is a small level to push in with your finger to release same. The hood will then be lifted and can rest against the top rain gutter frame. There is a hood support rod snapped into the hood also.
Keep us posted!
I was saying that the advice I was giving her was nothing to do with the battery. Just advice on starting. If you can't get it started you may kill your battery. If that makes any since. I confussed myself. I was just giving advice on a diffrent subject.
Hey guys!
Thanks for the advice. I DID get the hood open and found the support rod to keep it open. Then I tried to start it again. The first time I tried to turn it over, I heard a very soft click . . . then nothing, no sound. However, I checked the headlights and they do turn on plus I see that the ampmeter moves slightly (to the -30 side) when I try to turn it over. I have a very worn key (of course) so I do a lot of "wiggling" of the key to catch it just right.
Instead of calling AAA and having a huge tow truck come to my driveway and annoy the neighbors, I went to the local Wal-Mart this evening (a traditional Saturday habit) and bought one of those emergency charge packs that you clip to the battery. I plan to try it tomorrow a.m.
Any other ideas are greatly appreciated. And I don't mind advice from batteries to chokes. There'll be more questions from me in the future.
I'll try to post a photo soon. Î'll work on it to make sure it's not too huge a file.
See ya!
Sounds like you are on the correct path. The batter will have enouch juice in it to power the headlights sometimes but not enough amps to turn the moter over, hence the click. That click is the starter selnoid trying to engage the starter but the battery doesn't have enough power left in it to turn the motor over. What everyone said about starting is a good idea to. It may take a few cranks for the truck to start after sitting. Good luck! Let us know how it works out.
Stew
Usually a "click" or a "cliclicliclicliclicliclick" is a sign of low voltage. This may be caused by a dead battery, but if you find the same problem with your booster pack on, or fully charged battery, check all your electrical connections from the battery to the starter, from the engoine to the frame and the frame to the battery. Bad connections cause high electrical resistance and cause a drop in voltage. That means, even if your battery is fully charged, the full charge may not be getting to your starter. Check for tight clean connections. If needed you can clean them with a wire brush, just make sure that you don't contact a positvely charged part with a negatively charged part!!
HTH
If your still having problems, post back up. Work is bring to Portland tomorrow for a few days. I can pack some suitable work clothes and give you and your son a hand with the cruiser after I finish my real work.
Hey Cowgirl.
I assume you are in Portland Oregon.( there is also a Portland Maine) You can PM me and I'd be glad to help you. I have a 74 but I'm relatively mechanically inclined. Where in south west Portland do you live? I live in east Gresham.
Here's an update re: FJ 40 that wouldn't start
Good evening, all!
I'm a "commuter"Monday through Friday and couldn't get back to the FJ40 until today. Here's the latest: It started, after sitting for a week in freezing temperatures! I immediately drove it to Les Schwab who checked the battery and said it was only 2 years old and still good. Don't need a new batter. I explained about it seeming to "strain" or work hard to get the engine to turn over and they suggested having the starter looked at. So, maybe next weekend.
However, I didn't leave Les Schwab empty handed . . . my son (Harrison) noticed that there was a lateral wobble to the left rear wheel as he followed me to the shop. Bent wheel (original rusty, steel ones). Now I've got my existing BFG A/Ts on with new aluminum Rock Crusher wheels. Oooo! This makes the surface rust on the body look so much less noticeable.
Tomorrow I will continue cleaning the inside and then have to quit at dark and prepare for another week of commuting and working . . .
Next weekend I hope to get it to the welder's as one of the seat bolts for the driver's seat is outlined by a stress crack near the worst rust spot on the floor.
Then, back to the starter issue.
I appreciate the advice so please keep giving it. Otherwise, I won't learn nothin'!
Welcome to the MUD
There are many fine people here who can help you and your son breathe some life back into that old cruiser. Good Luck
thats awesome you got the truck running and prob. looks killer on it new wheels. keep posting questions even if you think there dumb. glad to help any cruiserhead
oh yeah
wheres the pics?
I think between you and your son, somebody needs to take a welding class at a community college or something. Not every one needs to do a lot or heavy structural welding, but being handy with even a cheap little flux core setup will make haveing an old vehicle alot more enjoyable. I have done a lot of big things on mine with welding using a variety of processes, but there are at least two dozen little welds any one could have made that really sped up little jobs that would have been a real pain if I had needed to take it to someone else to weld.
By the way, welcome.
