- Thread starter
- #101
It runs!
It runs!![]()
and I ran a braided stainless line for the VDO mechanical pressure gauge
you can post a pic to show how you attached the braided line to the VDO gauge .. ( I try it but can't and finish with a copper line )
And Summit sells this as a kit:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM-3229&N=700+115&autoview=sku
I can snap a pic for you tomorrow.![]()
Dude .. really thanks .. I got the link !
P.S. I never found it in summit .. my bad.
Along the same lines, when the engine gets hot, the fuel cut solenoid will not click. It stays running but If I turn it off, the solenoid will not reopen unless it gets over 14volts fed to it (without external power I currently get 12.4v at the plug)
Why is the solenoid reacting to heat?
Does this mean the injection pump is getting to hot? Is there some kind of temp sensor in the solenoid (I doubt that would be the case)
IMOP the entire pump housing feels hotter than it should, but I suppose it has coolant and engine oil running through parts of it, so theoretically it could be as hot as the block, is this correct?
