More real time Birf help
Colorado
More real time birf help...I haven't come across (unless I'mm missing it) any of the writeups covering replacing the races in the hubs..is this something that requires a mahine shop to properly press them in. I can see doing the races for the trunion bearings..those look easy enough.
Also, this topic has been run into the ground...is it safe to say that about 2 1/2 (14OZ) tubes of grease is enough in the knuckle and cavity?
Thanks in advance...
To get the races out of the hubs, use a punch from the opposite end of the race you are working on and pound out the race. The hub has little indentations that allow you to put a flat-headed punch on the bottom side of the race and smack it out--alternate between opposite sides of the race you are working on so you don't get the race wedged in ackwardly.
Secondly, putting a new race in, I like to use the old race to pound it in....use the old race's bottom side against the new race's top side. That way, when the new race is in, the old race will also be slightly "stuck" in the hub. Turn the nub over and you'll have the lip of the old race that you can tap right out.
Clear as mud? A vice is good to have around for this. If not a vice, I've used two pieces of concrete elevated off the ground so that you can drop the hub center through the area and rest the hub flanges on the concrete (or wood blocks would work even better).
Let us know if you need help.
-o-
Some folks cut the old race before they use it as an installer. That way it comes out more easily.
Thanks BENO...that makes sense. I've gotten a little ahead of myself and already put one of the hubs together :doh: so I would have to destroy the oil seal to get the inner bearing back out...unless there's a way to take it out without destroying it. I guess I could check with Toyota localy as well to see if they stock one... Is it critical that the race is replaced? It looks like it's in good shape with no scaring. I haven't done the other side yet and can at least replace the outer race on the one that is put together.
Those things seem like super hard steel...any suggestions on how to cut them?
I'm in luck, the local dealership has two oil seals in stock...not the C Dan price though! $20.07 Want to make sure I do this right though. This is going to call for another six pack tonight...:D
I've used a carbide tipped grinding wheel to cut a race already. Had to learn how to cut it due to putting in the trunion race upside down. Hint, do not install races the wrong way.
90311-62001.
Cut the race with a cut-off wheel or sharp hacksaw blade. If using a hacksaw, I would remove the blade and pass it through the race and then re-attach it and cut from the inside-out.
Good info...thanks a million!
Has anyone ever kept track of how many tubes of grease they've ended up putting into the knuckle and cavity combined?
I'm up to about 2 1/2 tubes on one side...
Thanks Bear...that's what I was hoping...I'm on the home stretch now replacing the races for the trunions.
Funny, I just sent you a message...I came across the write up on your LC and you mentioned you took all of the wood trim off. I would like to do the same on mine...did you have to use a heat gun and what did you use to get the glue off?
I've been reading through the FAQ about the rear axle service and it recommends engaging the rear lockers before pulling both axles out...I'm hoping this is not the case with the front. When I serviced the front I pulled both axles at the same time. They both went back in with no problem. In the future should the front lockers be engaged when pulling out both axles?
usually it is best to engage the locker...there is a slight chance that the locking collar can become out of phase or otherwise pesky to get the axle shaft through.
Best practice is to lock the locker before pulling the shafts in an e-locker 80 series.
One other trick you may have run across in some of the old threads, that I think helps with installing the new races is to put them in the freezer for 10 or 15 minutes to shrink them a little. They're a tight fit and take some banging to getting fully seated.
:beer:
Rookie2
I guess I lucked out then...got both of them back in with no problem.
Anyone know where this little washer is used in the rebuild?
:doh: Lets try that again...
You know Dan always sends them and I have never used them. No leaking or issues of any kind.
I just re did Sarah's front axle and since I re-used the old wheel bearings, didn't need to worry about those races. I did change the trunion bearings and races though. And 1 seized brake caliper.
Races - use a socket that matches the size of the race. Don't put the bottom ones in right side up which equals upside down. I did that once. Bitch to get out. I know I am late here, but trying to help. What I suggest takes BIG sockets. If you got no BIG sockets skip this post and use the old race.
