MORE DIESEL - B ENGINE PUMP QUESTION
El Salvador
I just installed a turbo on a B Engine (8 psi) but as you know, more air needs more fuel to get more horsepower.
Does anybody know how to calibrate the diesel pump to throw more fuel?
Thank you!
Wil
Unscrew the bolt counterclockwise 1/4 turn at a time and tighten the keeper nut and test your egts until you can get it to about 1100f under prolonged hard accelleration in 4th gear. Up a hill is better.
1st pick is the nut that holds the bolt in place.
Second pic is the bolt that limits rack travel. More travel= more fuel.
