Build Montina and The Blue Plate Special
Detailed Cali. Washed with Dawn and used CLR scrub technique and turned out good especially the roof was in great shape. I washed the original roof cover and will refoam when the top comes off. Engine runs great and she handles tight like a 40 with 124k miles. No brakes that will b next.
What did you use to clean the calipers before painting? Just brake cleaner, or did you acid dip them or do anything to remove the rust?
I did a rough clean with brake cleaner and a brush then soaked the calipers and rusted hardware in Evaporust. It does the best at dissolving the rust. I followed up with a little scotchbrite inside the cylinders to clean up any remaining rough spots.
Brakes are back together. I bought parts from my local toyota parts guy except the axle nuts and washers I bought from cruiser corps. I’m not sure if the spindle nuts had a different thread but the new aftermarket ones were tough threading on. Maybe the spindle threads might have been bad but I used the old one and it worked fine despite a previous repair shop used a screwdriver instead of the 54mm socket. Next I’ll flush the lines and do the bleeding.
