This is awesome, I don't even use my remotes cause it's so bad.
Could you solder small speaker wire to the factory antennas in the box and run them up the a-pillar?
Would it be simpler to solder onto the existing antennae or would that cause too much stress? Great mod BTW!
Would it be possible for a shop that specializes in custom wiring harnesses to make a simple plug and play extension just to route this box somewhere else in the vehicle?
Also thought about buying a used box off EBay in case I mess up my factory original. If I go that route does anyone know if re-programming would be required???
Gee, I don't know... I guess you could unplug the box and see if it starts before removing it entirely@Ayune Do you know if my LC will still start and run if I take the module out? Just wondering in case I start the process and don’t finish for a day or so...or if I need to do it all in one sitting.
Thanks!!
Wow, glad you asked! Second pic is the grounded copper, with “C1” “C3” etc. printed over it. The “301” section is the antenna circuit, or center conductor of the coax.@Ayune I pulled mine out and it is slightly different than yours. You can see on your board where you scraped for the copper...I started to scrape mine in the same spot and realized it was just plastic. My copper areas are different. Does it matter which area of copper I solder the outside coax wires to? Below you will see the areas on mine...I have a screwdriver pointing to each. Thanks!
Mine is 30 seconds. I believe it read that in the manual too.What is the normal time for the doors to stay unlocked? Looks like I get about 30 seconds before they lock back.
Awesome. The only suggestion I have is maybe moving the antenna up a bit so the shaft isn’t right next to the metal radio bracket. That may cause a slight “blind spot” toward the vehicle front. Test first and see if it’s an issue.Ok, so on my 2000...my board was different than @Ayune, but I scraped next to the C3/C4 and was able to get everything working. I haven’t tested the max distance, but will try tonight when I can see the lights lighting up.
You can see in the pic the bolt that needs to be taken out to get the orange box out. I tried the 10mm route and it wasn’t easy, so I did it with a long Phillips screwdriver. The angle was a little funny so I put the screwdriver into the Phillips head and pushed down a little and in so as not to strip the head. Worked well and pretty easy to get back in. I can’t imagine doing it with a ratchet....not much room.
The other pic shows where I mounted mine. For clarity, I ordered exactly what was in the first post from Digikey. Digikey shipped quick and everything was great.
If you are struggling with fob range this is well worth under $25 to do it.
Will report back on range.
That. Sounds. Awesome. I believe it was your amp bypass video that I really enjoyed watching.Wow, this is pretty cool. I'll have to play around with this. I'd love to make a relocation harness. I have some experience fabricating wire harnesses and could probably manage this all pretty well if I could source the connector.
Nice work, @Ayune !
While that may be true, it's also the right way to do things! I do my wife's Lexus projects to OEM quality... but my 21yo Landy... not so much lol.Haha, I got a lot of comments on that video saying it was a huge waste of time to do it all that carefully with a connector. Guess I'm just a little loony like that. Might as well take that lunacy and turn it into a revenue stream!
