mo_fj40's build
Is that Clutchee on the right?:grinpimp:
no he should be here tommorrow afternoon or thursday.
i called him tonight to see what was up. he is bringing the tires for my toy and hopefully jacks fj40 for my to make into an awsome crawler on rockwells.
well i picked up my trans tonight, Bill my tranny guy (ALL TRANS PLUS) 573-374-0710 did an awsome job as usual and at a great price. he was quick with my last minute frantic request to get one rebuilt. so hopefuly after this weekend i can get back onto the project and get it done for the grey rock event coming up in a couple weeks
went to flat nasty friday, glad i got to meet clutchee, cowboy, fro, mike,woody, and the others.
thank you clutchee for bringing up the swampers.
so i got homw and thought i really need to finish up on this 40 so i can go wheel it.
here are just the couple things i got done today. motor is in, motor mounts are tacked to frame. i think i am going to find a 2wd oil pan as the 4wd one just doesnt sit well with me.
tranny is bolted to the motor and in. transfercase is close to the 40, waiting on the novak input shaft to arrive.
dismounted 2 of my old 325/60/15lts today. man did that suck. had to back my dually over the bead to get them broke down. got 2 swampers mounted. i think i am going to like these.
then i moved the front jack stands so that i can mount my lower links. i have to cut that tubular crossmember out as my output shaft on the transfer will hit it.
i disassembled the interior so that i can start on the cage.
the motor is sitting a little lower than i wanted, but with a flat belly pan/skid i should be fine. ill brace that up with some 2x2x.25 square to keep it off of things.
the upper links are going to be close to everything in the front. at full compress i have about 1-2 inch clearance. with a 2wd oil pan i should have more. at least i know when i compress it fully that nothing hits. then ill just make sure everything works fine at full droop. that way i can also measure and build for my shocks.
i think ill use 15 inch travel for the front and 12 in the back. the rear ones will be splayed in so they wont need to be nearly as long.
so ill see what i can accomplish tommorrow. this waiting for parts is driving me nuts!!!!
Great progress.....keep going Gray Rock is around the corner!
It was great to meet ya, sorry for putting you to work welding on Fro's junk:rolleyes:
See ya at Gray Rock!
well this fj is fighting me the whole way. i think that i am going to have to use a 205 tansfer. i forgot about the right side of the 4l60e extruding about an inch. this is making it a pain to run a front shaft. it is flat right now and fits great!, but the pan and such is hendering driveshaft clearance.
the links are nice, i only have about 1 inch from the transmission to the link mounts on each side.
i will put on the 205 and see how that works. friday i will get more pics posted and get my star.
ill post the pics of the transfer (dana300) and how it is a pain and would work well with a th350 but not a 700r4 or 4l60e.
i have a th350 to use, but i really want the overdrive cause the 4l60 has a lower first gear and the overdrive.
if this persists, then ill just get pissed and v8 and rockwell it ans call it good.
How's it going? :rolleyes: Getting the rig built.......
Are you going to make it to Gray Rock?:confused:
got some progress tonight, got link mounts welded to the frame, just have to weld up the pass upper mount
also have to mount the lower mounts on the axle and finish the ones on the truss.
after that is done friday night, i will sleeve the lowers and align the front the make my spring buckets.
i am at ease with the 205 going in for now, i can order the 3:1 kit or live with it for now.
the engine is wired up and hopefully will fire off saturday. cage will be started shortly, been building up a tj monster for a friend who wants to wheel his next weekend.
clutchee, if my wife can get out of having to testify in court on next friday we will be a go for grey rock. she was the 911 dispatcher in the case. hopefully she will be able to. if not she wont get out of court in time for us to make the run.
well i didnt work on the fj tonight, i had a friend who needed a cage, so i started building him one, its a jeep, or is it, its all chevy 1 ton except the frame and body. anyway i started his cage. still waiting to see if my wife has to be in court for the grey rock event.
the toy will be done or ready to wheel at least by then (hopefully)
here is a pic of the cage i built, the one for the fj will look something similar
:bounce: Keep up the good work!:bounce2:
Hope things work out with the wife.
