mo_fj40's build
montreal mo
Website
www.ozarkoffroadfab.com
this is going to be a fairly quick build as i have events to get to. i will have to have it ready to wheel by the end of this month.
after talkinh with clutchee for a bit i have decided to start my coil spring conversion on my 74 fj40.
to start, the motor trans and transfer was sold. i have a 93 chevy blazer for a donor.
i will be using mini truck axles, 4.3 vortec, 4l603 transfer and a flat clocked dana300 twin sticked.
pics will come tommorrow night as i forgot the camera today.
i pulled the column today, unplugged all the wiring harnesses, and removed the clutch master cylinder and slave cylinder and steering box.
i pulled the motor and harness, column, and other parts off the blazer. i dont know how people pull them to fix them as i couldnt reach bellhousing bolts drop the trans without disaasembling the front end. so out came the torch and sawzall.
my plans are to pull the springs and hangars, front and rear tommorrow night. and start the designing of the 4 link.
im going to run jeep rubicon coils (fronts) on both front and rear. dual triangulated 4 link on front and rear. i will stretch the front out an inch or two and the rear about 4 inches. the tires will be 35 15.5 15 swamper sx's that clutchee is bringing up just before flat nasty event. i will use the blazer column and steering box.
my mini axles are 4.10 with the read welded and a true trac in the front (hopefully i get it installed in time). crossover steering arm is already on the mini axle and ill build custom trusses for the link tabs to mount to.
im really hoping my friends will come to help, but i think they will be hard to get in touch with. seems to always be that way.
ill give lots of dimensions and show some good pics. also if you need any of the things i am pulling off the fj40 that im not using pm me and we will work something out.
this is what i am starting with
MO, where are you located in MO? I'm in MO2. "Ozaerk Offroad?", guessin' in the Krazos somewhere?
Ed
i ordered 16 heims (rh and lh) 16 weld in bungs, 16 pairs of misalignment spacers and have them on their way now.
i have calculated the suspension to having 110% AS
i still need to order the input shaft for my dana 300.
i started on my design for my cage and tubular 1/2 doors.
no actual work on the fj as tonight was soccer night for my 3 kids.
so tommorrow is the disassembly of the original running gear
Get to work brother:eek: .....Flat & Nasty is around the corner then you got our event in Oct.
Can't wait to wheel with ya.
Oh yea....Jacks on for the rockwells;)
still waiting on parts. have the cage design down and going to start bending the tube fenders, cage and doors.
i have the new 4l60e and dana 300 ready. i have designed the motor mounts so that i can replace them at any napa. i have the template made to cut the rear 1/4s to allow for my 4 inch stretch of the rear.
i hope parts come quickly as id like to get this done by the flat nasty run.
ok i will quit slacking with the camera and show some pics. i have to deliver a fj55 back to its owner friday (it got my old motor) and then saturday after the kids' soccer games ill work on it and take some pics. im gonna fab the mounts and stab the motor and trans, then start on my links for the front. for cheapness, i have some 2" schedule 80 from something (havent a clue as it is heavy) ill use it sleeved for the lower links.
ill hopefullt get my stuff in from shipping soon. hard to build a linked front without the needed hardware.
the rear will be a snap, so ill do the front first. wish clutchee was here already with my swampers so i could set the ride height i want. i guess ill just have to guestimate the distances. i havent decided on how to mount the rear shocks, but im using 15" travels on the front.
so ill be building a nice custom hoop for them. i figure ill mount them high to keep a lower stance.
i picked up some 3/16ths flat (4x8 sheet) so that i have some skidplate material. strength will come from the 2x2 boxed.
just think i bought all brand new bushings for the leaf springs too.
so i promise pics this weekend!
got the front and rear end out today, cut off all the perches and crap off the mini toy rear and found out it is bent right where the perch is on the right side, so now im in need of one.
my truss and link mounts came in but the usps closed before i could get up there. i will post pics tommorrow as it is 12:17 am and im a bit tired. front end should be done in a couple days, i think ill just go with some coil overs if the wife lets me spend that kind of money before our vacation.
alrighty, welded on the front truss tonight and started making the crossmember.
i want my lower links to mount to the crossmember so im making a one piece unit the holds both and is also a skid pan.
started putting the front in place and seeing where the coil springs will go so i can build the mount for it.
Keep building brother....you got Flat & Nasty then the Cruiser Crawl :eek:
See ya next week:)
you could suggest the hardcore section, however this wouldnt fit.
this is not an extreme rock rig, nor is it a ton suspension or rockwells.
this is a daily driver rig that isnt affraid to be hammered on in the trails. as it is a v6 auto with mini axles.
i am building a hardcore rig soon with rockwells and 44 inch tires.
built the frame of my tranny crossmember tonight, drilled holes where the frame rivits are.
this is what i wil mount my lower links to. this will also bea flat skid pan too.
i have to set my tranny and transfer in to make sure i have good clearances.
the crossmember is 28 inches long and i cut them at a 45* angle so that they wont hang up. im debating on weather or not to make the mounting plates inside the frame or outside.
the rear link mount will be easy, so that is why im working on the front.
this weekend i get my other pair of front rubicon springs for the rear, and next week ill order my 15 inch travel shocks. so clutchee looks like it wont be ready for flat nasty due to not having a replacement rearend and not having all my parts, but if things work out next week, then ill have everything overnighted to get it ready for going to Alabama to wheel with you there.
ill post pics of the crossmember this week after i get my links mounted to it and my tranny in and dana 300 clocked flat
well didnt get much done tonight, was told my tranny would be finished friday (something with machining on the valve body) so instead of putting in the old and then taking it out, ill just wait till friday.
i have to go get heavy walled tubing anyway to redo my lower links, and pick up some oxy for my torch.
ill start the rear end when i find another, and i think ill do a 3 link even though they like to walk a bit when flexing out, but for everyday driving i wont have that problem.
ordered my shocks today, 15 inch travel fronts and 12 inch travel rears.
will post pics on friday night
Keep working! :D
Get this thing ready for Gray Rock.....see ya next week!;)
