been doing a bunch of work on my 60 lately, going through desmog stuff again,
Broke a motor mount out on the trail, so replaced both with OEM mounts
replaced my fan clutch with an OEM unit
replaced a bunch of cooling hoses all with OEM parts
found i had 2 failed VCV's , got 2 new ones coming from Beno.
Adding BVSV1 back into the circut, that should help cold weather driveability this winter. If you are BVSV'less like i am and drive in the cold, even with a ported vac source it can be hard to keep the engine running when you first set out..
found my intake / exhaust mani gasket had failed pretty badly, so replaced that with OEM toyo gasket and had my mani milled flat, sealed nicely now - likely for the first time ever since i did my original desmog back in 2009.
did a lean drop on the carb, adjusted idle and fast idle, reset timing,
all new Old Man Emu suspension bushings.. tossed in some LED cargo and dome lights .
shes driving like a new truck again!
