That makes sense. Should be able to reverse fairly easy.
coolant leak could be one of your heater lines on the firewall. Not an expert on compression but I believe those are considered very low. Have you adjusted the valves? Good luck with this as you have put a ton of work into it.Still have some problems, timed the engine, figured out I have possy gears in my rear end (hence all the random noises in my rear axle). I’m having compression issuesas well. All cylinders are at 100 out of 150 psi. Plus I now have a coolant leak behind the engine.
