Mechanical fuel pump?
I just had one go bad on the trail yesterday.
Darn pieces of junk - only lasted 32 years.
I'm going to stick with the mechanical, and rig up a "pre-wired" electric spare for emergencies.
Where's the best place to get an OEM replacement? NAPA, etc. has mechanical pumps, but they are generic types....
Rocky
maybe it was the altitude ;) maybe the truck prefers to remain on pavement in Tucson ;p :flipoff2:
Your carb is tuned at a lower altitude than what it needs at 8000ft. It is probably running rich at altitude and that could be what your poor running condition is.
The air at 8000ft is less dense than at sea level. So at sea level your carb mix air/fuel is good and you get good pick up. But at 8000ft your air is thinner so the mix is too much fuel not enough oxygen.
'Cept the carb is a Jim C. rebuild set for home base of 5000 feet...
Like I said, just dribble some fuel or starting fluid in and she starts back up.
TJ, Is it happening at 5k feet or 12k feet?
It is possible that an old pump at that alt and on a hot day won't supply enough pressure.
i really like the oem pumps when the diaframe inside goes and leaks fuel into the engine and the bearings and all go:rolleyes: maybe its just me:D dont get the lcheapo electric pumps.and ive noticed the farther away from the tank the more it struggles.on a 40 i always put them on the framerail right when its start to curve up
