mechanic/service issue
Austin, TX
Recently purchased a 96 land cruiser and took it to local land cruiser shop to do a check up and take a look at everything. Mechanic told me to replace oil pump, and brake pads rebuild steering pump so i gave them go ahead. Also i was missing a stud on both front axels and they fixed that as well. please note i drove truck for 40 miles or so while in my possession and hadn't noticed anything wrong, before taking vehicle to "specialist"
My father picked up vehicle today as i was out of town and told me while driving truck it slipped out of drive once and was not wanting to find drive. Also when he pulled into the drive way the front brakes were "smoking". I havent experienced any of this personally just what he tells me over the phone.
Well of course shop is closed for the weekend and i am no mechanic. does anyone think this issue could be something shop overlooked or left out before handing truck back after a sizeable bill.
Any help or input would be appreciated
Uh wait until you get home and drive it yourself and see if there is any thing you see, then ask
Congrats on the new purchase, welcome to Mud!
Nothing that the shop spec'd out would cause an issue with the transmission - you drove the truck for 40 miles since you got it? Did you check it out prior to purchase? If they did the brakes and the brakes smoked, I would venture a guess that you have an early model 80 with rear drum brakes? it is possible they could have been over tightened in the rear.
This weekend, drive it. See what it is doing. Post up here which wheels were smoking from the brakes. If the front, then something may have been put together wrong, because disc brakes can't be over-tightened. (drums can) Or it has some poor fitting or bad aftermarket calipers that don't fit new pads well.
My advice is don't overreact or accuse the shop of anything, just call them and have them look at it again. You bought the truck for $3800 from a guy who bought it at auction - it could very well have issues that he was not aware of. If you are mechanically inclined, then you will want to have a good relationship with your mechanic, and not piss him off by accusing him on your very expensive to maintain truck.
You also need to learn to become a mechanic, of sorts - these trucks were sold originally as luxury vehicles in the $50K range 25 years ago, and the maintenance costs at a competent shop will be of those to maintain a luxury vehicle. Plus, many shops won't have a clue how to work on several area with the nuance the LC likes. l've taken mine to trusted dealerships that would only let 1 or 2 of their staff touch things like axle rebuilds, alignments, brakes, basic stuff, because they are so different than newer vehicles that they Newbs out of mechanic school train to work on.
Without knowing what year his truck is, i agree with you it makes it really hard to provide him with any useful information.
He said front brakes. I've never seen disc brakes smoke.
well i slept on it and am a little less heated than yesterday. Vehicle is a 1996, again i asked them to look at everything and going in i knew it wasnt going to be cheap. Ill drive it around tomorrow and see if we can replicate scenario with smoke. was posting on here to see if anything jumped out at them as to what could have gone wrong
any way hopefully i can make things work out with shop as i was excited to finally use these guys.
will keep yall posted as to what we hear. thanks again
What possible reason could the shop have to suggest replacing the oil pump? Maybe they saw the dash oil pressure gauge (which almost always reads low) and just assumed the pump was bad. This part sounds suspect.
Agreed. Sounds odd.
I just replaced the calipers on my '94. The DS pads were thin-ish, the PS pads were nearly new. The brake dust on the pad pins had kept the PS pads from moving. The DS pads were doing all the work. I'd check the brake job and make sure the pins were new and greased. In my experience, very few shops do the job correctly. The pins should absolutely be greased. Check the FSM.
Depending on the pad material, and whether the mechanic's hands were clean, it might jsut take some time to seat the pads cleanly.
The xmsn shouldn't slip. Check the fluid. The procedure's in both the owner's manual and FSM.
No way anyone can tell the oil pump needs to be replaced, by a short inspection. You'd have to pull the sending unit, plumb a gauge and test. Unless it's pissing oil, of course, then anyone can tell there's a problem.
Based solely on your description, I'd ask for a thorough and detailed explanation of all test procedures prior to the work, and all work performed. If they won't provide it, to your satisfaction, leave and don't go back. Any good shop will want you to know why they did what they did and what they did. They want you to come back. I disagree that this is an expensive truck to maintain. You can find any number of shops willing to charge high prices, but that only means they're willing to gouge their customers. Some of the parts are expensive, because there are very few of them anymore. The work is straightforward, but not always obvious, which is why it's a good idea to find someone knowledgeable, experienced and willing to follow the FSM. Even if that someone's you. IMO, if you can read, you can maintain this truck. Please note I said maintain and not rebuild. The two terms are non synonymous.
IMHO, everyone who owns an 80 should own an FSM, for their model year. Even if you're not doing the work, you should care enough about your truck to know what's being done.
My semi professional guess is that smoking brakes=the calipers are stuck closed or the calipers pins are totally shot with no grease.
Check the color of the ATF fluid as well. BLACK = BAD
These rigs are 4 puck/piston calipers, and there is no place to grease pins like an american floating brakes are, again these are full piston brakes, I know there are pins that support the pads but I have never greased them just clean them
ok...you said they replaced a stud in both FRONT axles...then they must have taken appart the locking hub and may have left some grease in there...when braking, gets hot, grease turns to smoke...just in case check it...sometimes things are easy
When I read that about the oil pump my ears stood up too. Why would they do that? Was this a Toyota and specifically a mechanic that is familiar with Landcruisers? This is why I try to do everything myself.
My advice, as a mechanic, take it back to the shop and give them a chance to make it right. Our 80's are a bit more like old cars, they have adjustments. By that I mean sometimes the wheel bearings settle in some and need to be tightened after some driving or similar. I'm is Austin also and can help if needed, 512-786-1148. I'll be at F1 all day but can answer questions if you call. I'm guessing you took it to the one LC specialist shop locally, if so I have no doubt Edwin will take care of you.
So if they did studs they pulled the hub, could be overtightened wheel bearings and smoked one, or grease on caliper smoking off from the pads heating them up. Either way I'd check your wheel bearings and check your spindle, if they didn't do that right I'd also check torque on brake caliper should be 90ft lbs
drove vehicle today and no issues, also left vehicle outside for rains last night and no sunroof leak! spoke with my father face to face on issue and it sounded more like the front brakes locked up on him, he claims vehicle was radiating heat from up front. again seemed fine on my drive around the neighborhood today. will be taking back to shop on monday hopefully that can isolate issues, and i can get this beast back on road.
attached is photo looks like hub assembly is where smoke was coming from
