- Joined
- Jan 26, 2015
- Threads
- 14
- Messages
- 121
I have an FJ40 with a 1980 4bd1 engine. I'm not getting enough action out of the slave cylinder. The slave cylinder is from the NPR truck the engine came out of. The master is not the original, but is the Toyota master for my year Landcruiser (1969).
I bought this vehicle with the swap already done. I changed the clutch plate and it seems the only reason the slave cylinder had enough action before is because the old clutch plate was worn completely smooth.
I think my best option is to get a master cylinder that better matches my slave cylinder. It appears there was a different master installed at some point. You can see on the firewall other mounting holes and an outline of what looks like a master cylinder (picture below).
Does anyone know the volume of the stock toyota master cylinder?
Does anyone have any recommendations on a larger master cylinder I can replace it with?
Can anyone tell from the picture below what master cylinder may have been installed here previouslyndsey, based on the picture below.
