HI all.
I am going to replace the main battery ground.
Right now, it terminates at two places-one on the block to the left of the crank and one on the body just left of the ground lug of the battery.
When you all replaced the ground, did you a- make your own b- just use a single termination to the block c-both or d- just buy an OEM replacement?
The ground wire on the 22re is very small-smaller than I expected. I was planning on replacing with almost 100% more wire i.e. looks like 10g now or thereabouts and the std replacement straps at a parts store are usually 4g or thereabouts.
Thoughts?
Thx
Thoughts?
Thx
