Any of you got room, or budget for machine tools? Always wanted a mill or lathe?
Sandia and LANL are closing down their machine shops. Machinery and tooling will be auctioned off. Info follows:
Bentley & Associates, LLC Auction: Auction Posted Notification
I'm pleased to notify you of the upcoming Sandia, LANL & Others MAJOR Machinery Auction has been scheduled for this upcoming Wednesday, June 23, 2010 and Thursday, June 24, 2010 at 9:30 AM MST. The auction will be conducted onsite at the Bentley & Associates, LLC premises located at 4900 Pan American Frwy NE, Albuquerque, NM 87109.
The catalog will be posted to our website on starting this Thursday afternoon and will updated daily. There will be close to 4,000 lots.
This will be a GREAT auction. Look at the digital photos then make plans to attend this exceptional auction.
Sandia & Los Alamos National Labs & Others MAJOR Machinery Auction
Wednesday, June 23, 2010 @ 9:30 AM (MST)
Thursday, June 24, 2010 @ 9:30 AM (MST)
Auction Location:
4900 Pan American Freeway NE
Albuquerque , NM 87109
505-344-1812, Ext 131, 132 or 133
Viewing & Inspection:
Tuesday, June 22, 2010 8:00 AM - 4:30 PM
Terms:
15% Buyer's Premium
5% Discount for Cash, Cashier's Check or Check with Bank Letter of Guarantee!
Visa, Master Card, Discover, American Express
Live Online Bidding:
Bentley's is pleased to offer live online bidding through
liveauctionworld.com
Live online bidding buyers will have an additional 2.5%
Buyer's Premium added to their purchases.
Rigging Services:
Machine Services @ 505-263-9217
Machinery :
American Bullard - Model 32 Lathe w/ GE Mark Century 2000 S/N 81021
Haas - Model VF-OE Vertical Mill w/ Controller S/N 6650
Elox - Model Series N Wire Cut Wire EDM w/ Fanuc Controller
Giddings & Lewis - Model Bickford Horizontal Mill w/ Controller S/N 987-5028-8
Monarch - Model VMC 150 Vertical Milling Machine w/ Controller S/N 88523
Hardinge - Model HXL Super Precision Lathe S/N 241/1332
Optical Gaging Products Inc. - Model Opticom Qualifier 30 Optical Comparator w/ DiMetric plus Vision Compter S/N 0Q305
Giddings & Lewis - Model 351-T Horizontal Boring Mill S/N 5938
Giddings & Lewis - Model VTL-72 Vertical Turning Lathe (VTL) w/Controller S/N 50402438
Lucas Horizontal Mill
Hardinge VMC 1000 CNC Mill
64 Devlieg Spiramatic JigMil, Model 3B-48, S/N - G-222
Abrasive Finishing Burr Bench
DoAll 3247 Granite Table
Chemfree Smart Washer
Southbend 1640-W35-N2 Lathe
Hardinge HLV Lathe w/ Dovetail Bed & Taper
American 36" Lathe w/ 12" 3-Jaw Chuck
Leblond Regal 354 Lathe
Bridgeport Series I 2-HP Vertical Mill w/ Acu-Rite Readout
Cress C-20-H Kiln
Furnas Powermatic Grinder
Rockwell 8-200 Bandsaw
(3) Delta 17-900 Drill Press
Rockwell E-62946 Lathe w/ 4" 3-Jaw Chuck
Hardinge DV-59 Lathe w/ Dovetail Bed & 4" 3-Jaw Chuck
Delta 7000 RPM Shaper
Woodtek Planar
Rockwell 10 Contractor's Saw
Rockwell 10" Unisaw
Rockwell 46-450 Lathe *No Chuck
Centurion 500lb Chain Hoist
Cincinnati Angle Grinder
(5) Presto Pneumatic Carts
Cincinnati Lathe Parts
Amaco HF97 Kiln
(2) Bridgeport Mill Bases
Moore IBH Control Cabinet
Modern 200KVS Drill Press
(5) Baldor Dual Buffer/Grinders
Pallets Of ESAB Spoolarc 95 Welding Wire
Pulsa 7660 Wire Feeder
Airco Pulsearc 350/500 Welder
Miller HF-P Dialarc Welder
Lincoln Tig-300/300 Idealarc Welder
Craftsman 15 ½" Drill Press
Wagner Fm-1617 Drill Press
Delta 40-406/420 Jig Saws
(5) Rockwell Lathe Beds
Hunter DSP7701 Tire Balance
Ammco 7750 Disc Brake Facing Lathe
(2) Autocrib Automated Inventory Dispensers
Powermatic 1200 Drill Press
DoAll 24" Bandsaw
(10) Bausch & Lomb Acu-Rite X-Y Readouts
CABINETS:
(150+) Lista Cabinets
(30) 12-Drawer Tool Cabinets
(40) 16-Drawer Tool Cabinets
(20) 2 Door Tool Cabinets
(20) 1 Door, 8 Drawer Tool Cabinets
(30) 20-Drawer Tool Cabinets
(50+) Butcher Block Work Benches
TOOLING:
DoAll End Mills
Vardex Bits
Cobalt Union Twist Bits
Dowel Pins 1/8" - 4"
Bolt Threaders
Cap Screws
Step Blocks
Strap Clamps
Hogger Mills
High Speed End Mills
Ball End Mills
Corner Rounding End Mills
Punches
Files
Chuck Keys
Counter Sinks
Micro Stops
Drill Motors
C-Squeezers
Nuts/Bolts/Washers
Vacuum Chucks
Hole Saws
Large Soft Jaws
Pot Chucks
Drill Chucks
Tool Holders
Misc Jaws
Taps/Pipe Taps
Reamers/Steel Round
Round Brass
Dies/Die Handles
French Curves
Wire Strippers
Screw Cutters
Bright Boy Sticks/Wheels
Stainless/Brass Shims
Sanding Mandrels
Die Grinders/Mag Base
Torque Wrenches/Screwdrivers
Side Shields & Hookouts
5c St Step Chucks
Rubber Flex Collect Kits
Micrometer's 1"-12"
Music Wire
Acorn Adaptors
Counterbore Pilots
Ball Em Rig Studs
Counterbores without Pilots
Spot Facer Pilots
Solid Carbide Drill Bits
Sheet Metal Bits
Keenserts & Helicoils
Diametral Pitch Knurl with Holders
Brass/Steel Hexagon Broaches
Transfer Punches
T-Slot Cutters
Valentine Mini Mills
Knurling Tools
Lathe Mandrels
Spring Calipers
Stamping Dies
Expansion Mandrels
Boremasters
Boring Bars
Slitting Saws
Shell EM HSS
Tenth Pins
Carbide End Mills
Metric Drills
Metric Reamers
Parallels
Shank Tool Holders
Collets
Inserts
Stop Blocks
Jacks/Subplates
Threading Bars
Thread Combs
Saw Blades
Protractors
Transfer Screws
Scrapper/DR Burning Sets
Wheel Dressers
(100) Vice's 2"-12" (Kurt, Reed, Wilton)
Cutters/Milling Cutters
Screw Extractors
Tool Boxes
Pipe Racks
SCRAP METAL:
Aluminum Stock (30,000 lbs)
Steel Stock (10,000 lbs)
We look forward to seeing YOU at the auction!
Auction Location:
Terms:
15% Buyer's Premium
Rigging Services:
Machinery :
Cress C-20-H Kiln
Woodtek Planar
Rockwell 10" Unisaw
Amaco HF97 Kiln
DoAll 24" Bandsaw
CABINETS:
TOOLING:
DoAll End Mills
Vardex Bits
Bolt Threaders
Cap Screws
Step Blocks
Strap Clamps
Hogger Mills
Ball End Mills
Punches
Files
Chuck Keys
Counter Sinks
Micro Stops
Drill Motors
C-Squeezers
Nuts/Bolts/Washers
Vacuum Chucks
Hole Saws
Large Soft Jaws
Pot Chucks
Drill Chucks
Tool Holders
Misc Jaws
Taps/Pipe Taps
Reamers/Steel Round
Round Brass
Dies/Die Handles
French Curves
Wire Strippers
Screw Cutters
Sanding Mandrels
5c St Step Chucks
Micrometer's 1"-12"
Music Wire
Acorn Adaptors
Counterbore Pilots
Ball Em Rig Studs
Spot Facer Pilots
Sheet Metal Bits
Transfer Punches
T-Slot Cutters
Knurling Tools
Lathe Mandrels
Spring Calipers
Stamping Dies
Expansion Mandrels
Boremasters
Boring Bars
Slitting Saws
Shell EM HSS
Tenth Pins
Carbide End Mills
Metric Drills
Metric Reamers
Parallels
Shank Tool Holders
Collets
Inserts
Stop Blocks
Jacks/Subplates
Threading Bars
Thread Combs
Saw Blades
Protractors
Transfer Screws
Wheel Dressers
Screw Extractors
Tool Boxes
Pipe Racks
SCRAP METAL:
