To keep the reservoir from going empty. Just like brakes, if any air gets in the system, it can be a pain to get out. Air in the pump could damage it.
I see. So a full and thorough flush isn't a thing. Just bleed as instructed and move on.To keep the reservoir from going empty. Just like brakes, if any air gets in the system, it can be a pain to get out. Air in the pump could damage it.
Appreciate you. Hopefully 3 cans will be sufficient.You can thoroughly flush, but you'll need to keep the system topped with clean fluid as you do it. So a "flush" in the sense that you empty the system, then fill up with new fluid, is not advisable. But just as with brakes, if you can suction some old fluid out of the reservoir and replace with new fluid, it will reduce the amount of old fluid you need to bleed out.
The grinding is to reduce the chamfer on the end of sockets that have a rounded lip. That allows the socket to fit a little deeperI. I found the 13/16 socket to be a nice snug fit. You should be able to tap it on with a hammer. It does not sound like you need to grind it.Appreciate you. Hopefully 3 cans will be sufficient.
And I'm having trouble with the socket situation for the globes. 21mm and 13/16mm are too tight. 22mm has a slight amount of give. Whats this grounding down business? Sorry I just don't want a nightmare on my hands after I start.
This post got me out of a jam today. Thank you so much.Another option is to put a 3/8-1/2” hole in the red circle and use a flat end punch and hammer in a counterclockwise direction to knock it loose. This is what I had to do to remove the accumulator stuck onto the KDSS valve I dissected that was riddled with cancer.
Sounds about right.This post got me out of a jam today. Thank you so much.
Did my globes today.
2 came out no issues.
1 needed a twist socket
1 needed a hole like this one.
Bled each end out for air, then continued to bleed it & feed it simultaneously til the black / brown fluid started looking dark reddish.
Couldnt really tell the reservoir level. Loaded in about 1 2.5L can with plenty of spillage.
Everything seems to be working wonderfully.
Got back in there today and did the fluid flush.The grinding is to reduce the chamfer on the end of sockets that have a rounded lip. That allows the socket to fit a little deeperI. I found the 13/16 socket to be a nice snug fit. You should be able to tap it on with a hammer. It does not sound like you need to grind it.
I left the rear bolts on. Not worth the time. The bar bends down and you can wriggle the globes free.SQOD: So I ran out of time and have to stop my wrenching half way through swapping my original globes (did fronts) on my 2009 lx570 w 261k…. I’m assuming it will remain bouncy until I do the rears also?
It’s still bouncy and trying to manage my own fears/expectations.
Gosh those rear single bolts on the oem protection took an absurd amount it time to get off. Might need some more tools before reinstalling them…
Well I plan to answer my own question one evening this week. Hoping the bounce will be eliminated finally once I have four new globes. Fingers crossed.SQOD: So I ran out of time and have to stop my wrenching half way through swapping my original globes (did fronts) on my 2009 lx570 w 261k…. I’m assuming it will remain bouncy until I do the rears also?
Even one globe having a collapsed diaphragm can have significant effects on ride quality. So yeah, I wouldn't judge until you get them all changed and the system bled.Well I plan to answer my own question one evening this week. Hoping the bounce will be eliminated finally once I have four new globes. Fingers crossed.
Not sure if you saw this tip, but for anyone about to tackle this: put a floor jack under your breaker bar when you have it positioned on the globe. Put the slightest amount of pressure on the bar to keep it from slipping off the globe.This post got me out of a jam today. Thank you so much.
Fresh globes and fresh fluid but still bumpy leaves only the bleed. If your fluid truly is new, you can put it back in after a filter. . .Jumping in with the others tackling this issue. I replaced globes and have bled system 2 times still bumpy as heck. Could my rear height sensors be bad by chance e? All the way low and all high pics attached
Thank you I will bleed again and again and see what happens. I appreciate the help!!Fresh globes and fresh fluid but still bumpy leaves only the bleed. If your fluid truly is new, you can put it back in after a filter. . .
Another thing to try is a lot of up H to L cycles, like 20. Then bleed.
