If the service is free, take advantage of the fluid changes. I doubt they would cover AHC. You can do that yourself. It's about $80-$100 for the Toyota AHC fluid. Takes a few hours in your driveway to bleed out old fluid and add more behind the passenger tire wheel well area. Easy enough. Just be patient when it's all done and you are trying to get it to go up/down. Some guys will bleed a corner and start the vehicle back up to make sure it's pulling fluids throughout. I actually had a vacuum lock and was not able to bleed one corner. I took the same pump to add fluid and hooked it up to AHC drain line. It took some work to get the AHC fluid drained. That is kind of rare. Although others have mentioned if you are getting chocolate milk AHC fluid, it's got air in the lines. Regardless, It's worth the effort. Look at the color of my fluids from two different corners. This was at 89,000 miles. AHC had never been serviced. I replaced the globes while I was at it for around $400 - shipped from Japan. Toyota accumulator globes. Makes a big difference in ride quality. You should be ok until you approach 100,000 miles. Good luck.Our LX has its 60k service coming up and since we recently bought it as a CPO the next 4 services are free. This tempting me to have the dealer perform the 60k maintenance which includes all the big fluid changes. I’m torn for a few reasons, mainly because I prefer to do my own maintenance but I’ve heard tell of a couple good Lexus dealerships, I’m going to call around and make sure they will flush the tranny and AHC as required in the maintenance manual.
2 questions for the group are:
1. Should I just do this myself? The cost savings of the free services is tempting as the fluid alone for the t-case, AHC, and transmission really add up.
2. Should I have the AHC service done before installing the 24 gallon LRA that’s now sitting in my gym?
