LX570 AHC “Basics” - Added as sticky thread for AHC Issues
Hey everyone. I’m having some issues after replacing accumulators. The whole system seems to be rock hard while driving. Like there’s rods in place of the suspension. I’ve bled the system multiple times, there’s zero air out of any of the 5 bleeders. Everything checks out on techstream. Has this happened to anyone before?
Any help is appreciated. Thanks
Yep. Same thing. Even had a repair shop double check to see if switch was working. Rides stiff in all settings, but fully loaded, feels about right. I have no idea what’s wrong.
I have not read of this happening to anyone else. What happens when you change driving modes (eg. comfort, sport S, sport S+)? Also, what do you mean "fully loaded?"
Loaded with about 400lbs of cargo. No discernible difference in driving modes.
Have you cycled heights and driven around in each mode? Ie, drive around in low, then high, then normal
How much sensor lift do you have @rherrco? If possible remove all sensor lift and see how that feels.
I messed with the sensors only enough to even out the height. IIRC, only adjusted the DF, but even when I first got the LX about five years ago, there was no discernible difference in the modes. The PO even mentioned that when I test drove it. At that time it had about 100k on it. Now I’m at 135k.
There's an active test you can run in techstream to see if the damping actuators are actually being activated. Go to Chassis/AHC/Active Test and you can test each one. See if you are able to run them each through the motions.
Sounds like a plan. Now all I have to do is find a shop with Tech Stream.
I assume this active test is not something you can do with one of the non Techstream scanners (in the other thread)?
Would be a lot easier than Techstream!
I wish, best option is one of the Amazon tech stream dongles for like $25
I just replaced my globes as well. I really didnt pay that much attention to the modes but is there a meaningful difference between Comfort and Sport?
