Lx470 rear ahc not working
Vermont
Seeing if anyone has any input on this issue. Rear suspension will not raise on 2002 lx470. When I try to raise it the front raises properly but the rear is sitting all the way on bump stops and not moving. Replaced the rear height sensor and no changes. The pump seems to be running fine, but shuts off as soon as the front raises. No hydraulic leaks that I can see, fluid level is not low (actually higher than normal since back is completely down) and the springs in the rear look fine. There are no errors on dash, no blinking off ahc lights, and they will go to lo, N, and Hi, but rear will not move. Any help would be appreciated.
probably already did this right but was the rear sensor installed in the exact same spot? and was the threaded stud same length? do you have techstream? you may have to get a reading on the pressures.
  • Like
Reactions: GTV
Yes it was installed the same way. I do not have tech stream I think that may be the next step to resolve the issue.
Did you replace with an oem sensor? I would also disconnect the battery and see if that resets anything. Next step would be techstream.
FWIW, I had a hellish time trying to get tech stream running (got it to work exactly once) and ended up buying a scanner (basically a full tablet) that interfaces with AHC. Just throwing it out as an option. Kind of expensive at almost $400, but there are other less-expensive options that people have reported success with.
Mind if I ask the brand and model of the tablet that you purchased. I have been looking for a do it all scanner for a few months now.
the one I linked is the exact one I purchased, Xtool D7S. I purchased way more capability than I needed just to do the AHC interface on my LX as I have a few other dealer service-level issues I'm trying to diagnose: I have not yet successfully figured out how to reprogram the TMPS monior on my '17 subaru, but I was able to access the air bag computer on my corvette... I have seen others report success with scanners as low as ~$100, I believe the primary feature you're looking for is that it's bi-directional... I think the "Launch Creader" scanners are one that I've seen specifically mentioned members here having success with [example]
