Thanks @saucebox, this helped me make some progress but it's not working correctly. I can see the camera video now, but it doesn't come on automatically when I shift into reverse and also doesn't show the parking lines so I don't think the system is configured correctly. I went through some of the factory settings flipping a few of them to see if they did anything but doesn't seem to work. If someone has it working where reverse automatically shows it on screen and shows the parking lights, can you indicate what settings you used? Thanks!
I used saucebox's post 148 to install mine with no issues. I first made sure i could get the camera live working. Then just had to connect the reverse wire to my reverse lights so it clicks on automatically when put in reverse. I dont believe the canbus reverse works had to wire it manually.Thanks @saucebox, this helped me make some progress but it's not working correctly. I can see the camera video now, but it doesn't come on automatically when I shift into reverse and also doesn't show the parking lines so I don't think the system is configured correctly. I went through some of the factory settings flipping a few of them to see if they did anything but doesn't seem to work. If someone has it working where reverse automatically shows it on screen and shows the parking lights, can you indicate what settings you used? Thanks!
Install the second one now, later you wont want to take it all apart! Ask me how i know lolOk, great news! Got the reverse camera working automatically when shifting into reverse. As noted, you MUST connect the longer yellow wire in the camera cable to the reverse lights' 12V. In the lower split tail gate, there's a harness that runs from the body to the gate that has a bunch of wires in it. I just tapped into the black/red one. Then the unit side you want the shorter yellow wire tapped into the brown wire of the main connector into the head unit (G5 in the diagram). Now I can have the rear camera on whenever I want (by choosing the `reverse` option in the main screen) or automatically full screen reverse camera when I shift into reverse gear. Works quite nicely and wife agrees that the visual quality is significantly improved over the OEM one. I bought a second Teyes camera for the front which I'll tackle some other time
Thanks everyone for the help they provided here!
Taking it apart should be an easy task now.Install the second one now, later you wont want to take it all apart! Ask me how i know lol
I feel like the plastic frame will break/clips when trying to pull out the clips now. Its not OEM fitment its Chinese fitment with OEM clips.Taking it apart should be an easy task now.
I’m back to between this and the GROM. Grom has a group buy for $550 until July 15.
My LX is an 06 with April 2006 production date. Still seems hit or miss but damn it’d be nice to have this. The latest info of rebooting and resetting and selecting climate controls and the decreased audio hissing makes me want to pull the trigger. I don’t care about rear view camera but I do want steering wheel and knob controls to work and of course HVAC controls to work also.
Just got everything buttoned up and ac/radio/controls work. Without this thread it would have sucked, so thank you to everyone that contributed. One thing, has anyone gotten rid of the activation failure messages?
