Thanks yeah that is what I plan to do, I have ordered the gaskets. I will pull the pan off in the garage and drill out the holes. I was thinking I would just go with the "hot rod" size. I am ok with firm shifts, and if it helps with higher pressure and cooler running I am all for it.
Do you know if the trans filter is replaceable or is it a metal screen filter that is just remove, clean and reinstall?
I have found a small exhaust leak at the downpipe so I will have to take the truck back to the shop they have ordered a Borg Warner EFR specific V-band and I am also going to change to the higher boost waste gate actuator, since the tuner seems to think that the low boost actuator I have isn't holding as much boost to redline as he would like.
Have you checked your mileage after the turbo? Haha driving around town I love hearing the turbo spool and I am only getting around 9mpg, but I think we can still lean it out a little, and I am sure after a while I will be used to it and I won't be boosting all the time.
