LX450 Transmission?
Bozeman
Hey all,
I'm new to the 80 series and am planning to baseline my LX soon. Went to order a trans filter from my local NAPA and gave them my build date, December, 2005. Their system shows the trans to be the A341E but my limited research shows it should be the A343. Is either of us right? Am I rolling with a Supra trans?
TIA
I could be missing what you're asking here ...I'm no math wiz, and I don't have my glasses on but Im not sure a stock 1996 LX450 has an original tranny with a Dec 2005 build date
The filter on your trans is a fine mesh screen, can be cleaned. They run very clean, so, if it's clogged, you have bigger problems. The trans has a drain plug, most just drain and fill. The pan goes on with RTV sealer, so even if you want to remove the pan, no parts are needed.
I guess my question really is: What transmission is in the LX450 with a 12/95 production date? FSM was of no help.
Thanks again!
time travelling transmissions are difficult to identify
The LX450, was only a 1996 and 1997 model year and only came with the A343F. But like Tools said, just get some brake cleaner and spray out the metal mesh filter, you will be fine.
Pretty sure its an A343F, but as others have advised, you absolutely will not need to replace it. Just clean it a little at most.
IF its a 343, while you have the pan off....you will have the option of increasing the line pressure via an adjustable valve on the valve body. No tools required.
You might want to research that. Most of us leave it as is from the factory, but it can be done, if you need/want to.
