Sounds like you solved your issues. I finally fixed my ground issue. About 2 years ago, I had installed a JVC headunit to replace the stock one, and the harness I got, used the factory amp. I had hissing from a ground issue that would not resolve no matter what I did with the ground or a ground loop isolator. I finally installed the headunit chassis using plastic bolts, so there was no part of the headunit chassis that contacted any metal on the truck. Then I only heard faint hissing at idle.
One of my front speakers recently blew, and I took advantage of Circuit City's liquidation and picked up some 6.5" Polks for the front and 5.25" for the rear. I decided to try to bypass the amp, to do the job right. Well, lo and behold, once I located the factory amp, I figured out where that Walmart harness connected (I had bought it when I originally installed the headunit, but couldn't figure out where it was supposed to hook up.)
Moral of the story... BYPASS THE FACTORY AMP. Absolutely no ground issues now, and I did nothing special during re-installation, other than ditch the amp integration harness and instead, used the bypass adapter harness. I did extend the harness by ~22". Now the console sub is disconnected, and with any decent set of speakers and an aftermarket headunit, you will not miss it at all. In fact, the bass is better without it, since it began to distort at a lower sound level than the aftermarket speakers do.
