Lutz Auto - Speedometer Correction Device
I was skimming through the thread and saw mention of the GX470 but that was several years ago. Is the GX470 included in those plans?
Hi, We have looked into the GX470 and are still trying to find a good plug and play solution without having to cut wires.
Another new one. This one is for the new Landcruiser 250. We need a tester for the new Tacoma as this may likely work with the new Tacoma, but is untested.
We are pleased to bring you the fully plug-and-play Lutz Auto Speedometer Calibrator for the LC250. This speedometer calibrator is fully adjustable and has no latency issues. After installing and calibrating it, you will forget that it exists! Ships quickly from the central coast of California. This Speedometer Calibrator is designed to adjust your LC250 speedometer to display the correct speed, compensating for any modification that affects the speedometer calibration (ie. tire size). This will also update the rate of the odometer to match the corrected speed.
NOTE: We should be testing soon with a GX550 to make sure it works for both - ad will be updated when the Lexus GX550 is confirmed working.
Installation was very easy. I’m still off by 3-4 mph. Need to play with it to get it right.
We have added many models including the whole new line of Toyota/Lexus 4x4's and most of the last generation. If it shows out of stock, we just need to create full instructions for how to remove the vehicle interior.
So can l order an lx570 unit even when showing out of stock? Seems straight forward from the video I saw of you guys installing it on that truck at dissents shop.
Yes, Shoot me an email Sales@LutzAuto.com. We can build one for the LX570, we just don't have photos for the cluster removal instructions. It will likely be similar to the 200 series. Let me know if you have a 2008-2015 or 2016-2021 in the email and we can get you setup. I can also supply some TIS instruction help if needed.
Still wanting one for my ‘05 Tundra…
Just some install notes for the LX570 and likely the LC. I wanted to keep the adjuster accessable in case I changed tire size, or even tweak between brands since there is variation.
Lots of room behind the side panel, so I drilled a hole big enough to reach in and bump the buttons. Attached the adjuster with DBL sided tape. It all gets covered by the beauty cap.
With the cap off, easy enough to pull over and make you bump adjustments while tweaking. Not accessable while driving.
