Lunchbox locker and 35"'s
Spicewood, Texas
My gear guy says no, that 35" are too big and will break it. What are your thoughts? :confused:
Thanks,
Jeff
Get a new gear guy.
Shoot. I didn't know that. My Cheaplok has been in since CM2001. And now I'm running 35 swampers...No problem
Thanks, thats what I thought, just needed a sanity check.
The PO of my dad's 68 FJ40 had a lockrite in the front and rear runnning 35's for many years with no problems. In fact the rear was #005 ever produced for a coarse spline rear axle. Lockrite gave him a free fine spline one in exchange for the old one as they wanted it for their display case.
Pighead-
Saw you and the pig cruising down Capitol Ave 2 weekends ago in front of Pesanos/Zocalo/Drangonfly. Looked and sounded great.
-Brian
Lock Right has a generic warning against using tires over 33 inches, but this includes axles that have weak carriers, like Dana 30s and GM 10 bolts. Cruiser axles have a much stronger carrier.
:beer: Here's to y'all up there in Sacratomato town. I'm a native of South Central Sac: Fruitridge and Stockton. I lived at 16th and Q too.
lockright and 38's here also i did have one go bad . after 5 yrs may have been the way i set it up
i didn't check any of the tolerances i just pulled the spiders and chucked it in . the teeth on the locker just wore the corners off . eventually one day out in the woods it just would not hold anymore
i had to pull rear shaft and drive home in 4x4 front wheel drive. i pulled it when i got home and it just looked worn out .
see pic see shiny rounded corners
I you are doing a lunchbox, just do it yourself. It is super easy even with the semi-vague instructions. I paid to get my lockrite installed the first time, but I put an aussie in my front diff in about 30 mins (not including removal and reinstall of the diff). There is just not that much to it. That being said, I much prefer the detroit I have in the rear now. Much less querky.
Buzz Killer
With all the + posts, let me be a buzz kill :flipoff2:
I was running one for a somewhat short time on 36 TSL SXs. I also have a V8 and probably use the extra torque too liberally, but I went through my lunchbox way too quick to tell a buddy to try it. I did NOT check clearances upon disassembly, but everything was new when I installed in. I'm sure it was just bad luck, but it was enough for me to Lincoln Lock the rear from now on. I just found it to be unreliable when I needed it most. Although, I've had good luck with one in the front for whatever it's worth...
Good luck on yours...
35 ssrs and lunchboxes over here,
cruiser lockrights are huge compaired to others I have seen. A heep buddy of mine breaks the pins in his d30 lockright fairly reguraly with 36's but nothing other than those pins. They always send him new ones when he breakes them
