I wanted to highlight one of my designs sold over at
TAG - a mount for the Scangauge II:
This puts critical information (real time coolant temp and transmission temperature) directly in your field of view whenever you glance down at your gauge cluster - I've really enjoyed having my personal SG II mounted here in my 2005 LX470.
It perfectly contours to the steering column in all directions (achieved via 3D scanning the column & using that to guide the CAD) and attaches via 'snapping' onto the column around the turn signal/windshield wiper stalks recesses - no drilling required! It's ultra secure & doesn't interfere with the stalks at all. It's also engineered to not interfere with the auto tilt/retract of the steering column, and is tucked back as far as it can be while still achieving that.
The kit includes a 1' black flat ethernet cable + ethernet coupler to allow you to route the cable along the top of the steering column without drilling, where it's nearly invisible. It also includes a removable sunshade (pictured) to improve readability in ultra bright situations.
These get 3D printed in ASA for heat resistance & UV stability.
Note: It does block VSC + center diff light, and depending on your seat/steering wheel settings & height you may obscure the odometer as well. These aren't issues for me, since I find the info from the SG to be much more important, but I wanted to ensure that's disclosed. The first picture is taken directly from my vantage point while seated in my driving position to give you an idea of what it looks like.
