Lugs Nuts Backing Off?
San Diego
Website
youtube.com
Hey Guys
Anyone else having this problem?
This has happened to me on 3 seperate occasions and is now preventing me from being able to drive my rig and feel comfortable, i am constantly worrying about my nuts! :D
I am super anal on my maintence and torque specs and such, and everytime i remove the wheel, i make sure it is torqued perfectly.
My rig probably sees MUCH more abuse and washboards roads then most, and i am thinking that this is the cause, but what would be the fix?
Any idea what may be causing this? Anyone else experiencing this?
Thanks
Are you lubing your nuts? :D Maybe your torque wrench is off? If it's always the same wheel I'd check for a cracked wheel. Any debris on the hub or wheel that might gradually crush down and make the nuts loose?
I have only had this happen when they were not torqued. Is the surface behind the tire smooth. Just wondering out loud if there was something that would cause the slightest vibration, if that would be enough to jar them loose.
You didn't say if it was one or all tires. If it was all tires I would check your torque wrench.
What are you torqueing them too? I do mine a little higher than spec to about 90-95
Stock wheels? Are you running the correct lug nuts? 93-94s used a conical... 95-97 flat, w/washer.
Studs loose/stretched?
I had this happen for the first time ever. I just installed freshly powder coated stock alloys and the left front lost a lug nut and a center cap. Never noticed a thing except a slight shimmy when turning a corner. This happened on a long drive on a major highway which was rather smooth.
No lube and I gun my nuts on with an impact, they were tight! I think the PC interfered with the rims seating on the hub because after arm stronging them on they were fine for the ride home and the wheeling in between.
Well, I for one have had it happen, once. Really unnerving!!!
Factory rims on my 62, after driving from Edmonton to LA and back as far as Seattle, I had the front driver's side nuts come loose (not off) on the interstate. Now I make sure the studs are lightly lubed to be sure it is the face of the nuts that's biting, not the threads. And check them periodically.
antiseize or lube can throw off the torque setting but I would expect that to mean the wheels are tighter than nominal at the same torque reading, not less. Are the studs maybe particularly dirty or rusty?
This actually is a common problem for vehicles that see a lot of time off road, the vibration will loosen them.
On our dedicated off road trucks we have to check them every morning, and we will STILL have at least one wheel get loose.
Help me out here, I was always told not to use any lube on wheel lugs. What's the real story?
I think that with the proper torque either clean and dry or lubed will hold just as well.
The proper torque will be different for both. If you take yours wheels off often the lubed studs will be in better shape for a longer lifecycle. Over 20 years ago I had 2 studs break when trying to remove them. Since then I have always used some type of lube with not 1 issue in over 20 years.
Dry fasteners throw off the torque reading. Lubrication ensures that it is correct. Ask the folks at ARP.....
That depends on the application. Most torque specs are for (clean)dry threads, unless specified otherwise. Oiled threads will allow more applied force to the fastener at the same torque spec versus dry threads.
I'm not sure if oiled threads would have more of a tendancy to come loose, but it would seem so.
-Spike
