Looking for help on what I might have overlooked. Just spent the last few days replacing both front calipers, rear calipers and all pads, ebrake and front pads. I removed the lspv and used the stock front tee that was taken off the drivers side. I removed all the rear lspv stuff and arm, the lower line I broke off in the rear and the front, removed the front 2 port T and bracket, removed the 3 port bracket at the master cylinder. I then routed the rear line of the master direct to the abs unit where it was connected to the 3 port unit on the master cylinder.
Bled the brakes and everything went well. Got lots of air out and bled each corner till there was no more air bubbles. I did the pass rear, pass driver, pass front, drivers front. The only odd thing I noticed is that the front drivers rebuilt caliper had a 8mm bleed port on it which I have never seen, they have always been 10mm. I also got some milky white fluid coming out of the pass side front caliper. I am guessing this was maybe something like oil in the caliper from the rebuild process.
When I went to test drive it the brakes are now worse than before all of this work. Brake pedal goes straight to the floor. The brakes still "work" but are very soft and spongy and is overall not safe to drive. I see no leaks whatsover and I am not losing any fluid.
Any thoughts? I tried to "activate" the abs unit by going over a speed bump and slamming on the brakes but it did not work as the brakes are not strong enough to even activate the abs. I am wondering if opening the port on the abs unit has introduced air into it that I now must get out? I have never unhooked or messed with the abs unit at all.
I know others will say ditch the abs all together but for now I want to try and make it work if possible but am open to deleting it if the unit is worn out or broken as I don't want to spend big $$ to get it working again. But if I can get it working by a simple procedure that would be good.
Any help from other that have been here before is appreciated.
